drilling rotor screws
Old Jan 14, 2005 | 08:55 AM
Consistent1's Avatar
Default drilling rotor screws
I did search and only found this thread
https://honda-tech.com/zerothread?id=1063191
when you drill out a screw, what are you actually doing? Are you using the drill to turn the the screw into metal shaving and no longer a screw...I can not get my rotors off and needed to the last time I changed pads.
Old Jan 14, 2005 | 12:17 PM
clayne's Avatar
Default Re: drilling rotor screws (Consistent1)
Use an impact driver. It costs about 20-30$ at Sears and is made specifically for screws like this.
Then never install them again.
Old Jan 14, 2005 | 01:28 PM
Perfectionist's Avatar
Default Re: drilling rotor screws (clayne)
I second that. (Although I did replace mine)
Old Jan 14, 2005 | 01:47 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Consistent1 &raquo;</TD></TR><TR><TD CLASS="quote">
when you drill out a screw, what are you actually doing? Are you using the drill to turn the the screw into metal shaving and no longer a screw...I can not get my rotors off and needed to the last time I changed pads.</TD></TR></TABLE>
you end up drilling off the head of the screws. then you can remove the rotor completely. and use a vice grip to take whats left of the threads in the hub.
ive had to do this before i got an impact driver. impact drivers certainly are the right way to take em out. but if its already stripped, you just gotta drill em out. (chisel method can work too)
Old Jan 14, 2005 | 02:32 PM
sabotage7's Avatar
^^^ what they all said is correct!......and dont put those stupid screws back in or you'll be doing it again next time! i hate those screws!
JBirch_97Prelude
Jun 25, 2008 05:25 PM
dcdcdc
Jul 2, 2006 10:18 AM
Ants
42
Jun 7, 2005 10:08 AM
Drag-On23
Oct 28, 2003 08:29 AM
PatrickGSR94
Apr 15, 2002 12:51 PM
