d16y7 ecu on d15b7 will it work?
Old Jan 14, 2005 | 08:27 AM
Race Egr's Avatar
Default d16y7 ecu on d15b7 will it work?
basically just as topic says i have a obd1 d15b7 motor if i throw this in my ek hatch would a obd2 d16y7 run the motor or would it run like crap do to a diffrent size engine?
Old Jan 14, 2005 | 11:08 AM
tgreaves's Avatar
Default Re: d16y7 ecu on d15b7 will it work? (NAPIER)
It should run fine.. But your tuning is going to be a little off..
Whenever you run an ecu that is not exactly meant for the engine it was tuned for then your going to have off tuning.. If its for a stock motor I would just run it and be done..
Old Jan 14, 2005 | 11:56 AM
egizzle8
Guest
Posts: n/a
Default Re: d16y7 ecu on d15b7 will it work? (tgreaves)
It may throw a CEL for the Crankshaft Speed Fluctuation Sensor I think since the obd1 and older engines never had the sensor. I'm not really sure how you would mount one on the older engines either?
Old Jan 14, 2005 | 12:05 PM
tgreaves's Avatar
Default Re: d16y7 ecu on d15b7 will it work? (egizzle6)
Forgot about that.. It might need some sensors that your obd1 motor doesnt have..
Old Jan 14, 2005 | 12:13 PM
egizzle8
Guest
Posts: n/a
Maybe switch to OBD1 and just buy a jumper harness? OBD2 is hassle and not tuner happy
Old Jan 14, 2005 | 12:40 PM
Katman's Avatar
yeah, just like the others have mentioned, you'll run into some sensor issues, these ones mainly when using a non-OBD2 SOHC engine + Y7 ECU in an EK:
- As mentioned: CKF sensor (located on OBD2 oil pumps)
- possibly 2nd 02 sensor (unless you reuse your existing one's)
- reuse your existing Y7 exhaust manifold
- 3-wire IACV - btw, you'll want to reuse your complete Y7 intake manifold on the B7 engine, it should bolt right up.
AdrenalineAngel
Dec 10, 2012 12:16 PM
turbo97coupe
Mar 31, 2009 07:44 PM
streetcartuner
Mar 30, 2008 10:25 AM
B18C_EJ8
Mar 6, 2006 10:41 AM
Ehron
Oct 15, 2003 08:14 AM
