proportiong valve ?
Old Jan 13, 2005 | 07:39 PM
Race Egr's Avatar
Default proportiong valve ?
If I upgrade the front brakes on my eg hatch to gsr one's and still retain the rear drum do i need to change the proportiong valve and booster?
Old Jan 13, 2005 | 07:41 PM
sohcvtec1995's Avatar
Default Re: proportiong valve ? (NAPIER)
i would do the booster, not to sure on the valve
Old Jan 13, 2005 | 07:43 PM
Del Sizzle's Avatar
No.
Race Egr's Avatar
Default Re: proportiong valve ? (sohcvtec1995)
do the booster to a gsr? will a gsr booster bolt right up?
Old Jan 13, 2005 | 07:52 PM
CA6VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">do the booster to a gsr? will a gsr booster bolt right up?</TD></TR></TABLE>
<FONT COLOR="royalblue"> The Booster bolts on, but one of the lines need to be moved. </FONT>
Old Jan 13, 2005 | 08:14 PM
Street Ghost's Avatar
Default Re: proportiong valve ? (CA6VTEC)
I believe you can just use a 15/16 Master Cylinder and be done with it. Since you still have rear drums, you should be able to keep the stock prop. valve and be okay. You can get the 15/16 Master Cylinder from a 1991 Honda Civic EX Sedan; its a direct bolt on to your stock booster.
skill178
16
Oct 9, 2011 04:38 PM
ntensehonda
Nov 9, 2005 11:58 PM
the_0ne
22
Apr 15, 2004 09:54 PM
jdmcivicferio
Jan 5, 2003 09:23 PM
jdm92accord
Jan 31, 2002 08:15 AM
