What ECU For OBD1 DOHC ZC?
ok, i know the pg7 ECU is better for 88-89 ZC swaps.
is there a better ECU than my stock DX ECU for an OBD1 '90 ZC motor?
i know very little about ECUs and am assuming the pg7 is strictly for OBD0 cars.
Re: What ECU For OBD1 DOHC ZC? (NorcalHB94)
well not sure but wonder if anyone has a site with ALL ecu codes and what they go with or know them ALL??
Re: What ECU For OBD1 DOHC ZC? (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">well not sure but wonder if anyone has a site with ALL ecu codes and what they go with or know them ALL??</TD></TR></TABLE>
Imagine that: http://www.pgmfi.org
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorcalHB94 »</TD></TR><TR><TD CLASS="quote">ok well from the looks of the list there, i guess i'm looking for a P29 ECU...thanks for the reference </TD></TR></TABLE>
No problem.
If you have trouble locating a P29, I have the raw .bin file, and it would be easy and relatively cheap to convert a P05 or P06 to P29 specs.
No problem.
Re: What ECU For OBD1 DOHC ZC? (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">
No problem.
If you have trouble locating a P29, I have the raw .bin file, and it would be easy and relatively cheap to convert a P05 or P06 to P29 specs.</TD></TR></TABLE>
You can also use uberdata/neptune/hondata. Im running a Neptune ecu on a p28 ecu for my dohc zc.
liam
No problem.
liam
Re: What ECU For OBD1 DOHC ZC? (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 »</TD></TR><TR><TD CLASS="quote">You can also use uberdata/neptune/hondata. Im running a Neptune ecu on a p28 ecu for my dohc zc.
liam</TD></TR></TABLE>
That solution is just way more expensive if he does not have access to the proper hardware. The cost to chip a P06 and burn an OEM .bin to a chip is minimal.
Re: (cherroneballs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherroneballs »</TD></TR><TR><TD CLASS="quote">what about a obd 1 ls ecu? should work</TD></TR></TABLE>
It runs - runs rich. You are better off running a stock DX ecu with a fpr and raise the fuel pressure a little bit.
liam
liam
Uberdata is free and just as easy as burning a chip. The Neptune/hondata is more expensive yea, but im just giving all the options.
liam
liam
i know very little about ECUs </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 »</TD></TR><TR><TD CLASS="quote">Uberdata is free and just as easy as burning a chip.
I was trying to set him up with the best tune for a relatively stock setup, not 37495767 hours of researching how to tune and use the available software.
99sonicbluegsr
03-28-2005 05:01 PM
