tranny trouble
Old Jan 13, 2005 | 05:48 PM
integra4991's Avatar
Default tranny trouble
Alright, I have a problem and before i go spending more cash on parts i wanted some second opions. Its a 94 with the stock tranny and right before i took it off the road for the winter i started having problems shifting from time to time. Id be driving for example and id stop at a light and be siting in neutral and go to shift into gear when it turned green and the car wouldnt go into any gears and just grind if i try to go in reverse (not at a light obviously). Id then have to **** the car off to get it into gear and then start it in gear and move at the same time. Most of the time it works normal after this. I just replaced the clutch master and the slave cly. and the problem still is there. My only thoughts were it could be the clutch so thats my next step but i figured id get some other opions.
Thanks
Old Jan 13, 2005 | 05:52 PM
bg-33p's Avatar
Default Re: tranny trouble (integra4991)
hey, i've had this EXACT same problem. my problem was relieved for a little while cuz my oil was low. so check ur oil. n well after like 2 days it just wouldnt shift at all anymore. so i put it in the shop n the mechanic says its the clutch..btw i have a 94 gsr....so this could be ur problem: a bad clutch
JDMTegraR
Jul 26, 2005 05:24 AM
951dc5
Jun 26, 2005 09:41 PM
EMphaticONE
Aug 22, 2004 01:07 PM
HavokB18
Jul 26, 2003 05:32 PM
94thundergrey
Sep 11, 2002 04:50 PM
