Engine Rebuild questions
Old Jan 12, 2005 | 09:55 PM
billzcat1's Avatar
Default Engine Rebuild questions
Yes, I'm a noob to Hondas, but I've rebuilt VW and Audi engines and I can take them apart in my sleep now
I had a few basic questions on the rebuild process. First: what book or service manual would you recommend for the important specs? Bearing clearances, ring gap, torque specs, etc. I've seen a few "How to build a Honda engine" books on Barnes and Noble and what not.
Second - are their any brands of main/rod bearings you would particular recommend (or recommend avoiding?). Also, since I'm not that resourceful for Honda parts yet, where would you recommend buying said items? Last question on bearings - do they use an integrated thrust bearing on the #3 main journal like I'm used to seeing on aftermarket bearing sets for just about everything else?
I guess thats all I need to know for now. Thanks a ton! Of and feel free to contact me if you need machine work done. I like making car parts
Old Jan 12, 2005 | 10:11 PM
Butcher's Avatar
Default Re: Engine Rebuild questions (billzcat1)
n00b
Old Jan 12, 2005 | 10:12 PM
PrettyLude's Avatar
a helms manual
for the bearing part, its just what you like using, i have seen acl and oem bearings work with success.
i personally use only oem bearings
to buy bearings, try at http://www.hondaautomotiveparts.com
Old Jan 13, 2005 | 01:50 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
http://www.slhonda.com is cheaper on bearings. http://www.helminc.com for manuals.
Old Jan 13, 2005 | 02:13 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billzcat1 &raquo;</TD></TR><TR><TD CLASS="quote">do they use an integrated thrust bearing on the #3 main journal like I'm used to seeing on aftermarket bearing sets for just about everything else? </TD></TR></TABLE>
Yep.
1988dxsedan
Engine Machining & Assembly
105
Jan 8, 2017 12:06 PM
Boost_allways
K Series
Aug 9, 2009 09:03 AM
.BigSexy
Feb 10, 2007 10:46 AM
signorelli21
Oct 22, 2004 07:06 AM
HondaGuy02
May 17, 2004 01:38 PM
