Problems with my EG
Old Jan 12, 2005 | 11:32 AM
gsronhatch's Avatar
Default Problems with my EG (PLEASE HELP!!)
I have 93 Civic hatch VX with a d15b7 block and a d16z6 head. Anyway i remember when i ran my car hard and i would stop in a gas station or anywere and shut my car off, then i would try to restart it again it would start and all of the sudden it dies. Then i have to wait till the car cools and then start it and go. The first time i bought my car it did not have any hydrolic fluid in for the clutch so my clutch began to decrease, then i came to a light and it would not go into gear, i didnt have any money because i just spent $1,500 on the car so i can buy brake fluid to put in it, but anyways it was to late. So then at every place i would come to a stop i would put it in 1st and start my car and then go. When i got home i put DOT3 and got my clutch up and running, then i went to start my car and it died. After that it did not get any spark so then i changed the coil and in the process i saw that the ignition module was cracked but still working. I put everything back into place with the new coil and it started. About a month later the car would begin to die everytime i would try to start it after i ran it. Then a buddy of mine gave me the d15b7 engine and right away we did the head swap and put the distributor from the VX and it fit good. Could the distributor be the problem???
Modified by gsronhatch at 12:43 PM 1/12/2005
Old Jan 12, 2005 | 11:35 AM
komat's Avatar
Default Re: Problems with my EG (gsronhatch)
https://honda-tech.com/zerothread?id=554053
DO NOT ATTEMPT THIS SWAP ON A CIVIC VX, THE PISTONS HAVE TOO LARGE OF A DISH AND THE COMPRESSION WILL END UP BEING TOO LOW
could be that
Old Jan 12, 2005 | 11:38 AM
PLAN:B's Avatar
Default Re: Problems with my EG (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=554053
could be that</TD></TR></TABLE>
That would suck
Sounds like a possibility
Old Jan 12, 2005 | 11:39 AM
gsronhatch's Avatar
i have the b7 block the only thing i have from the VX is the distributor
Old Jan 12, 2005 | 11:41 AM
gsronhatch's Avatar
at first i thought it was the fuel system and like an idiot i changed the fuel pump and filters
Old Jan 12, 2005 | 12:48 PM
gsronhatch's Avatar
Does anyone else have an opinion about what else could be the problem
Old Jan 12, 2005 | 01:02 PM
Pat McGroin's Avatar
IF you fixed all the problems and whatnot with the clutch and everything else, have you tried the main relay?
I remember starting the car tog o get gas, it made it to the gas station. Then, after filling it up with gas, I tried turning the car on. After 5 minutes of trying I stopped, when I cam back after like 5 minutes, the car started.
The problem hasn't occured ever since I replaced the Main relay. It's around 50 bucks new from Honda if you have not replaced yours yet. Or you could resolder the points on the Main Relay for cheaper.
Here are some sites:
http://techauto.tripod.com/mainrelay.htm
http://www.markl.f9.co.uk/howt...y.htm
Pic courtesy of turbogixxer from a good program he has.
Old Jan 12, 2005 | 01:32 PM
gsronhatch's Avatar
Default Re: Problems with my EG (Pat McGroin)
i have not tried that yet but i will, thanks alot and ill let you know how it went when i do it. Just to be on the safe side you want me to change the PGM-FI Main Relay??
Old Jan 12, 2005 | 01:55 PM
gunnis's Avatar
Yes the pgm-fi main relay on that diagram is the one to change. this is your main fuel relay and definatly not an uncommon problem on this year civic.good luck.
Old Jan 12, 2005 | 01:59 PM
gsronhatch's Avatar
Default Re: Problems with my EG (gunnis)
thanks
Old Jan 12, 2005 | 02:45 PM
92civicb18b1's Avatar
I know a real good way to fix it if in fact it's cause the head swap made your compression too low.
Get a turbo kit.
I really think that's your problem though, so you should start buying turbo parts or put the old head back on or figure something out.
Old Jan 13, 2005 | 03:11 PM
gsronhatch's Avatar
Hey i changed the main relay, and i ran it around and it still does the same problem, but atleast now i can hear my fuel pump turn on and off. Let me know if there is anything else you know.
Old Jan 13, 2005 | 03:16 PM
kidkombo's Avatar
main relay like what was said above.....**** needs to cool off homieskilletbiskit jk
Old Jan 13, 2005 | 03:28 PM
Phantastic's Avatar
i had the same problem with my hatch but the motor i have is a ls and when i was searching for the problem, i found that the coil in my distributor was bad so i changed it. while i was changing the coil in the distributor i always changed my spark plugs and wires also since they were beat.
Old Jan 13, 2005 | 06:19 PM
gsronhatch's Avatar
Default Re: Problems with my EG (Phantastic)
Well i decided that im going to change out the whole ditributor and if that doesnt work i think im going to blow the car up. Nah jk but really if that doesnt work im going to take it to a mechanic and let them take care of it cause its getting pretty bad.
ale_malo
Feb 16, 2014 06:33 PM
onesoejourner
Oct 26, 2011 08:35 AM
aaronISthrowed
Sep 13, 2007 03:48 PM
BIGthings
13
Feb 19, 2006 09:15 PM
redteg1
Apr 28, 2003 04:12 PM
