Oil Pressure Gauge Questions
Do i need to "T" at the block on the sender unit?...
If i dont will it send the ecu into safe mode? (b16a2)
Or Does the Stock Sending Unit Just Kick on the Warning Light?
sorry for the newb questions.....
Yes you will need to T off the block where the stock sender sits. And yes, it's a 10 dollars sensor that just kicks the idiot light on if it doesn't sense and pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Sivic »</TD></TR><TR><TD CLASS="quote">thanks for the quick reply....!!!
BTW, the sender is just above the oil filter on the back of the block.
</TD></TR></TABLE>BTW, the sender is just above the oil filter on the back of the block.
I was wanting to run some type of Line from the block to the "T" ..probley located on the firewall, So i wouldnt have the extra weight. Is there a website that has such a thing?
i did a diy when i had my rsx. you can hook it up with the greddy sandwich adapter/stainless line, and remotely mount the sender.. i ended up taking it out of that car and putting it in my wrx, hated that car and put it in my 00Si (finally own a car)! If anyone is interested in a "safe" way to do it without any worries check it out..
http://forums.clubrsx.com/show...guage
...you may have to create an account and login to see the pictures....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Sivic »</TD></TR><TR><TD CLASS="quote">I was wanting to run some type of Line from the block to the "T" ..probley located on the firewall, So i wouldnt have the extra weight. Is there a website that has such a thing?
This is a good idea... just use a 1/8" fitting and some hose/braided line... mine broke off in the block and it was a pain to remove ("easy out" my ***)
euclid
Oct 16, 2004 07:18 PM
