Oil Pressure Gauge Questions
Do i need to "T" at the block on the sender unit?...
If i dont will it send the ecu into safe mode? (b16a2)
Or Does the Stock Sending Unit Just Kick on the Warning Light?
sorry for the newb questions.....
Re: Oil Pressure Gauge Questions (99Sivic)
Yes you will need to T off the block where the stock sender sits. And yes, it's a 10 dollars sensor that just kicks the idiot light on if it doesn't sense and pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Sivic »</TD></TR><TR><TD CLASS="quote">thanks for the quick reply....!!! </TD></TR></TABLE>
BTW, the sender is just above the oil filter on the back of the block.
Re: Oil Pressure Gauge Questions (Ricey McRicerton)
I was wanting to run some type of Line from the block to the "T" ..probley located on the firewall, So i wouldnt have the extra weight. Is there a website that has such a thing?
i did a diy when i had my rsx. you can hook it up with the greddy sandwich adapter/stainless line, and remotely mount the sender.. i ended up taking it out of that car and putting it in my wrx, hated that car and put it in my 00Si (finally own a car)! If anyone is interested in a "safe" way to do it without any worries check it out..
http://forums.clubrsx.com/show...guage
...you may have to create an account and login to see the pictures....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Sivic »</TD></TR><TR><TD CLASS="quote">I was wanting to run some type of Line from the block to the "T" ..probley located on the firewall, So i wouldnt have the extra weight. Is there a website that has such a thing?
This is a good idea... just use a 1/8" fitting and some hose/braided line... mine broke off in the block and it was a pain to remove ("easy out" my ***)
euclid
10-16-2004 07:18 PM
