Runnin out of gas with 1/4 tank left after walbro install
Old Jan 12, 2005 | 09:49 AM
mchuang's Avatar
Default Runnin out of gas with 1/4 tank left after walbro install
Man Everysince i put in a walbro pump i run out of gas with a lil more than 1/4 of a tank left. Was I suppose to use the lil net the walbro pump provided or use the one from my stock honda pump?
Old Jan 12, 2005 | 09:51 AM
underpressure02's Avatar
Default Re: Runnin out of gas with 1/4 tank left after walbro install (mchuang)
use the one with the pump. Are you sure you really have a 1/4 tank left? Or is your fuel guage just off?
Old Jan 12, 2005 | 10:29 AM
mchuang's Avatar
Default Re: Runnin out of gas with 1/4 tank left after walbro install (underpressure02)
No it is not off. It was working fine 2 weeks ago before pump. So you use the little small one that it comes with
primeredbeast's Avatar
my crx would start fuel cutting around a little below 1/4 normal thing don't let gas run too low
Old Jan 12, 2005 | 11:06 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchuang &raquo;</TD></TR><TR><TD CLASS="quote">Man Everysince i put in a walbro pump i run out of gas with a lil more than 1/4 of a tank left. Was I suppose to use the lil net the walbro pump provided or use the one from my stock honda pump?</TD></TR></TABLE>
which pump is it?
Old Jan 12, 2005 | 11:08 AM
nsxmatt's Avatar
I run a 255 walbro and have not had any problems running it down to below the E
Old Jan 12, 2005 | 11:43 AM
MaxBoostC1's Avatar
Default Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">I run a 255 walbro and have not had any problems running it down to below the E </TD></TR></TABLE>
same here
Old Jan 12, 2005 | 11:49 AM
turboteg2nv's Avatar
Default Re: (MaxBoostC1)
There's an article on c-speed racing or somewhere else, i'll find it if you beg. check to make sure you got the tampon looking thing down far enough in the tank, you may not have installed it properly.
Old Jan 12, 2005 | 11:50 AM
btotherizzle's Avatar
I used the pickup that came with the kit and I was running out before a quarter tank. Put the stock pick up back in, it worked for me.
Old Jan 12, 2005 | 12:44 PM
mchuang's Avatar
Default Re: (turboteg2nv)
hook it up dawg find it for me
Old Jan 12, 2005 | 05:34 PM
adseguy's Avatar
Default Re: (mchuang)
yeah mine did that too. You really shouldn't be going below 1/4 tank of gas as the sediments dend to be picked up and clog a filter.
Old Jan 12, 2005 | 06:38 PM
Default Re: (adseguy)
http://www.theoldone.com/articles/fuelpump/
the info you need is down on the bottom
Old Jan 12, 2005 | 10:50 PM
W O T's Avatar
mine does the same, all new **** including tank and my engine sometimes sputters if I try and take it below 1/8 of a tank when revving out a gear
I always fill up way before then though, whenever I see a good gas deal, always have $100 in 20's in my car for races or gas
Old Jan 13, 2005 | 04:06 AM
Importracer_001's Avatar
I'm not having that problem mine goes all the way down to Empty.
There is an article somewhere how to install a fuelpump.
Old Jan 13, 2005 | 04:08 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Importracer_001)
i'm just guessing but i think he knows how to install a fuel pump. although i can run my em1 down past the e-mark, but i stillhave my stock fuel pump
Old Jan 13, 2005 | 04:50 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Runnin out of gas with 1/4 tank left after walbro install (primeredbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primeredbeast &raquo;</TD></TR><TR><TD CLASS="quote">my crx would start fuel cutting around a little below 1/4 normal thing don't let gas run too low</TD></TR></TABLE>
My CRX and my hatch did the same - I never went below 1/4 tank or it would run out of gas
Old Jan 13, 2005 | 04:57 AM
B18c1turboedEK's Avatar
Default Re: Runnin out of gas with 1/4 tank left after walbro install (HybridCRX88)
Mine does the same thing!!!! i tought my gauge was bad, then i put the gsr one back and it worked perefect!!!
Old Jan 13, 2005 | 05:27 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Runnin out of gas with 1/4 tank left after walbro install (B18c1turboedEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1turboedEg &raquo;</TD></TR><TR><TD CLASS="quote">Mine does the same thing!!!! i tought my gauge was bad, then i put the gsr one back and it worked perefect!!!</TD></TR></TABLE>
I guess it is just a Walbro thing
Old Jan 13, 2005 | 07:20 AM
mchuang's Avatar
its the 255 high pressure i think it has something to do with me using the stock strainer
Old Jan 13, 2005 | 08:23 AM
rpm9100's Avatar
It happened to me also, 1/4 tank then it would die.
I found out I had the wrong pump.
Old Jan 13, 2005 | 08:30 AM
Si Integra's Avatar
Default Re: (rpm9100)
My DA (90-93 teg) had the same problem with the walbro 255.
When I put one in my DC (94+) No more problems.
Never did figure it out. Both were installed properly.
Old Jan 13, 2005 | 08:36 AM
King-Kong's Avatar
Default Re: (Si Integra)
what the deal is with the walbro's is that if you have a crx or ef civic the fuel pumps are longer and lower than the 92-95 eg civics, and so since the pump, if you are using a 92-95 civic walbro, cannot reach the bottom of the tank it will not pick up the remaining 1/4 tank of fuel. I have the same problem on my crx, i have a 92-95 civic walbro 255 intank pump in my car and when 1/4 tank comes my way my car boggs and stalls, very bad for the pump may I add. Maybe you didnt get the proper size pump for your car or whoever installed the pump didnt go a very accurate job. just my .02
later ... chris
juba_x
Aug 25, 2012 08:12 PM
sanman000719
Jul 5, 2011 06:35 AM
BigMike0147
Jun 7, 2011 11:56 AM
a1320addict
Oct 15, 2005 12:46 AM
Malgerus
17
Jun 14, 2003 08:08 PM
