Oil coming out of breather after boosting help!
Old Jan 11, 2005 | 10:16 PM
Lude_Behavior_97's Avatar
Default Oil coming out of breather after boosting help!
i have a 5th gen on about 7-8 lbs of boost and after running it hard around the breather area of the valve cover there is oil, also the breather is soaked. I heard of this and also my oil measuring stick poping out, but wat is it i should do to fix it.
Old Jan 12, 2005 | 12:41 AM
SKDRCR's Avatar
Default Re: Oil coming out of breather after boosting help! (Lude_Behavior_97)
If you're boosting it's gonna increase crankcase pressure.
That's probably why there is so much oil coming from there.
You could always install an oil catch can.
Old Jan 12, 2005 | 01:28 AM
pentaq's Avatar
Default Re: Oil coming out of breather after boosting help! (SKDRCR)
Or check your pcv valve.
Old Jan 12, 2005 | 06:10 AM
Paluce's Avatar
Default Re: Oil coming out of breather after boosting help! (pentaq)
ya, check/change the PCV.
Old Jan 12, 2005 | 09:50 AM
PrettyLude's Avatar
blow-by
Old Jan 12, 2005 | 11:09 AM
Honda318dx's Avatar
Default Re: (PrettyLude)
blow by from broken/cracked/not sealing rings... it wont get better..
Old Jan 12, 2005 | 11:15 AM
Mykizism's Avatar
Default Re: (Honda318dx)
i concur
Old Jan 12, 2005 | 02:19 PM
homesauce's Avatar
Default Re: (Mykizism)
Some oil there is normal thought right?
Old Jan 12, 2005 | 08:30 PM
Default ..
Will gettin a 2mm headgasket and arp studs make it safer
Old Jan 12, 2005 | 09:55 PM
PrettyLude's Avatar
it will not make it safe, blowby is from broken/cracked/not sealing rings, how would a headgasket make it safer, the damage is already there
Old Jan 12, 2005 | 10:38 PM
jdmlude01's Avatar
Yea your rings are gone. I have the same problem. I would check your oil freaquently now cuz your probally burning it. Sounds like its time for a rebuilt block and increase the boost for you.
Old Jan 18, 2005 | 01:50 PM
SOHKis's Avatar
i was having this problem, did a comp. test and found that my #3 cyl was down to 130 (on my gsr). Just rebuilt the block, arias pistons & rings and eagle rods, but i'm still getting a small amount of vapor coming out of my valve cover breather. i've hooked catch cans to both PCV sys. and to the valve cover breather. i'm only getting the vapor our of the breather, and it's a strange "milkylooking" substance, not straight oil. what's wrong? did the rings not seal? i've put just over 500miles on the new setup.
Old Jan 19, 2005 | 06:41 PM
Default ..
I am goin to biuld the block what should i use. Should i also use a thick headgasket if im biulding it?
Old Jan 19, 2005 | 07:20 PM
SprayLude93's Avatar
that sux !!! fix it now or blow it up later
zimmy709
May 18, 2012 03:16 PM
x_doug-x
11
Apr 1, 2008 10:56 PM
calvinkw1
Nov 18, 2005 06:49 AM
p1ccoloz
Jul 6, 2003 04:09 PM
WhiteSTi
Apr 24, 2002 05:59 PM
