Gsr Tranny problems
Old Jan 10, 2005 | 08:51 PM
stickyfingers's Avatar
Default Gsr Tranny problems
i just recently swaped a jdm gsr in to my girls hatchback. Everything went perfect till we filled up the trans with fliud, it began to leak,No big deal we tightened it up for the time being with intenstions of going back and using rtv sealer to take care of thr leak.put the gsr linkage on with the honda pin through the linkage (the linkage is not upside down it is the right way.)So then i hop in the car to start it and it fires right up i slowly let the clutch out and the car stalls(so it was in gear) start it up again and as i go to put it in neutral i notice that i cant find neutral let alone any other gear.(might i add that i think the case split before i bought it) The second or third time of trying to find neutral i found it,but i can take the shifter and do figure 8's with it and any other pattern you can think of.
playing with the shifter i can feel linkage moveing smoothly but not finding any gears????
So that is where i stand!
This is to somebody who knows a thing or two about trans// on the outside of the case there are those to bolts that when you take them out a spring and a single ball bearing comes out of each if they are not properly put back would everthing i just explaned be the effect?????????????????????????????????????
ONLY REPLY IF YOU HAVE A SENSEABLE ANSWER NOTHING OF THE OBVIOUS I HAVE ALREADY CHECKED AND RE-CHECKED THEM
Old Jan 10, 2005 | 08:54 PM
Default Re: Gsr Tranny problems (stickyfingers)
And please if you read my thread whether you help out or not give it a bump so it will stay fresh wont be lost in those crazy amounts of threads
THANKS TO ALL THAT READ IT WHEATHER YOU WROTE IN OR NOT!!!!!!!!!!!!!!!!!!!1
Old Jan 11, 2005 | 12:59 AM
Outkast95LS's Avatar
bump
Old Jan 11, 2005 | 04:15 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stickyfingers &raquo;</TD></TR><TR><TD CLASS="quote">... on the outside of the case there are those to bolts that when you take them out a spring and a single ball bearing comes out of each if they are not properly put back...</TD></TR></TABLE>Does this mean you took them out? Yeah, it can do that. Those are part of the mechanism that interlocks the shift forks to each other. Mess it up & you can engage 2 gears at the same time, this locks up the tranny. If you can move the shifter all around, maybe there's more stuff broken in addition to that??
Old Jan 11, 2005 | 05:59 AM
GDM Z28's Avatar
Default Re: Gsr Tranny problems (JimBlake)
bump for you
Old Jan 11, 2005 | 07:23 AM
snatch's Avatar
Default Re: Gsr Tranny problems (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">If you can move the shifter all around, maybe there's more stuff broken in addition to that??
I tend to maybe agree with this. If the shifter can do figure 8's, it sounds like something is wrong with the gear selector inside the tranny. Try taking off the shift linkage at the tranny and using an allen wrench through the bitch pin slot to shift it. See what it feels like then.
Old Jan 11, 2005 | 07:37 PM
Default Re: Gsr Tranny problems (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">
I tend to maybe agree with this. If the shifter can do figure 8's, it sounds like something is wrong with the gear selector inside the tranny. Try taking off the shift linkage at the tranny and using an allen wrench through the bitch pin slot to shift it. See what it feels like then.</TD></TR></TABLE>
That was on of the things i did and no matter how many times i tried to find a gear with the allen wrench i could always go side to side as it would in neutral...???
Old Jan 11, 2005 | 07:41 PM
please try to keep this thread "fresh" so if somebody else has some input
THANKS AGAIN
BUMP
BUMP
Old Jan 11, 2005 | 07:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Does this mean you took them out? Yeah, it can do that. Those are part of the mechanism that interlocks the shift forks to each other. Mess it up & you can engage 2 gears at the same time, this locks up the tranny. If you can move the shifter all around, maybe there's more stuff broken in addition to that??
No i didnt take them up i just knew from a previous trans i helped my friend with ...See the deal is i bought this full swap from north jersey and they told me everything is "mint" but at the same time who knows what went on over in japan or where ever it was last (cali)what i think is that somebody obviously took it a part and then put it back together and did realize they have to be lined up with the shift forks..... at least that is what i am hoping for
Thanks
Old Jan 12, 2005 | 04:04 AM
JimBlake's Avatar
Well, if those interlock ***** & pins are messed up, you probably gotta dismantle the tranny to fix it.
kmeng
Oct 14, 2010 11:34 PM
skUnK2jdm
11
Dec 13, 2008 11:43 PM
MRXMUFFIN
Aug 31, 2007 11:49 AM
davidluko
Dec 2, 2006 10:29 AM
coachkellum
Sep 9, 2004 02:03 PM
