d16 swap to b16
If you can use the search button, and get creative you can find the answers that you seek. It's in the upper right hand corner of the page. Try it out, get used to using it, it is a great tool
Searched for "b16 mounts ", came up with 9 results in archives, third from the top yeilded this info:
1.) Rear transmission mount bracket - 1999-00 Civic Si - 56827-S04-N10 $28.86 Reuse the stock rubber mount.
2.) Driver's side engine mount bracket - 1999-00 Civic Si - 11910-P30-000 $40.12. Use the stock Civic 96-00 bolt studs and all other stock parts at this location.
3.) Front transmission mount bracket - 1994-01 Integra. Use the stock Civic 96-00 end rubber mount and bolt stud.
4.) A/C mount bracket - 1993-97 Del Sol. Use the stock Civic 96-00 A/C compressor.
5.) Upper transmission mount bracket - Stock Civic 1996-00.
see my prob. is i dont feel really comfortable installing a motor myself, but theres nothing more i want than to learn, and i learn by doing, but you think this may be to big of a risk?
bamboosted
May 12, 2010 10:06 AM
drowzysleeper
Sep 17, 2005 09:00 AM
GeekinEK
Nov 21, 2004 10:41 AM
blueintegra90
Jun 11, 2004 04:03 PM
Or if you can afford the down time, build the bottom end of the d and go high compression!
