How do you take off this ignition peiece
Im looking to swap this with my current one, how do i remove this?
Its threaded on one end, but the other end looks like it is filled in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi »</TD></TR><TR><TD CLASS="quote">It looks like its an aluminum rivet or stud. Air grinder should be suffient enough or a decent dremel. - Darrell</TD></TR></TABLE>
dremel
dremel
Like everyone else said, use a dremel and cut slots in it. But replaces them with studs and a nut, this will make it a lot easier if you ever have to replace it again. Or use a bolt.
Just changed that on my 90 si hatch and those screws cut like butter with a dremel, slot em deep and back them out with a flathead. Only took me 5 mins to get both out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon »</TD></TR><TR><TD CLASS="quote">We had to use a hammer and chisel on mine because they were in there pretty good. But other than that, they come out just like a regular screw.</TD></TR></TABLE>
Use the chisel and hammer to unscrew it. Easiest way to do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx »</TD></TR><TR><TD CLASS="quote">
Use the chisel and hammer to unscrew it. Easiest way to do it. </TD></TR></TABLE>
right way to do it!!
yea i just replaced that on mine too. i cut slots in it with a hacksaw black and unscrewed it with a screwdriver. when i put it back in i used new bolts, but the head was too big to use a socket on (the socket woulndt fit in the space) so i trimmed the bracket down a little bit, and cut slots in the heads of the new bolts then screwed it back in with a screw driver. btw, you cant use a nut since the other half of the ignition peice is already threaded (you already knew that) and the bolt size and pitch is 8x1.5mm i believe. costed me like a dollar from the hardware store for both bolts.
edit: and oh i almost forgot, they arent filled in or riveted or anything like that. they are shear bolts. they are designed to be installed with a ratched and when they are tight enough, they head just twists off. you could always just get new ones if you wanted.
Either do what others say, dremel or air grinder, but first try needle nose vise grips, they slowly become looser over 14 year, i was about to slot mine, but tryed needle nose vise grips for the hell of saving time, and it worked mint
