anyone ever used these
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Farnsrocket »</TD></TR><TR><TD CLASS="quote">Are they plastic? Looks like they need to be glued on.
yeah, that's kinda what i was thinking, i was hoping someone migt have a better idea
</TD></TR></TABLE>yeah, that's kinda what i was thinking, i was hoping someone migt have a better idea
You don't have to glue anything. All you do is place it between the gauge and the surface you are mounting the gauge to and tighten from the back. Now instead of the gauge rim sitting directly on your dash etc... it will sit on this adapter at an angle.
Yep, I'm using three of those to angle the gauges mounted in my audio console. It helps reduce paralax error
Pardon the messy photo, I'm doing some re-wiring changes. About a year ago I had Autometers mounted in the same way.
Modified by SLPR at 6:59 AM 6/18/2003
Just to clear up any confusion, they aren't meant to be used with the push in style mounting, like the autometer pillar pods. They are meant to work with the screw on brackets that hold the gauge in by clamping to the back of the gauge mounting surface.
When I was first doing my gauge setup in my car last year, I used PVC piping from Home Depot to make something similar to that. Just angle cut it, then sprayed the white tubing black.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLPR »</TD></TR><TR><TD CLASS="quote">
that's one nice freakin install on the Techedge display, i was thinking of removing my clock in my 'Lude and putting it there, right now it's just in the little pocket that's below the headunit
</TD></TR></TABLE>that's one nice freakin install on the Techedge display, i was thinking of removing my clock in my 'Lude and putting it there, right now it's just in the little pocket that's below the headunit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude »</TD></TR><TR><TD CLASS="quote">
i was thinking of removing my clock in my 'Lude and putting it there</TD></TR></TABLE>
Heheh, I've been thinking about doing that, too. Right now I have it velcro'd to the dash above the clock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a »</TD></TR><TR><TD CLASS="quote">I can picture it now...
bahahaha gay bar graph. does it rescale when ricers are present?
</TD></TR></TABLE>bahahaha gay bar graph. does it rescale when ricers are present?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XDEep »</TD></TR><TR><TD CLASS="quote">
bahahaha gay bar graph. does it rescale when ricers are present?</TD></TR></TABLE>
Haha... I don't have to have one of those... I have a Bel 980 and always says "Gay-man... detected".
(For those of you actually wondering, yes, I know it's saying "K-band"
Im using those angle rings. You need to cut the aluminum brackets that hold the meter in. One leg will need to be much shorter than the other.
Also you may have to grind the edges of your panel, as the angled meters require an 'oval-ish' hole instead of round.
