b20 vtec turbo... what head?
Old Jan 10, 2005 | 11:55 AM
b20vtechatch
Guest
Posts: n/a
Default b20 vtec turbo... what head?
i have my block all set up........
b20b honed
84mm bore ross pistons 8.5:1 cr
eagle h-beam rods 5.394
arp bolts for mains and connecting rods
atc bearings
block gaurd
b20 crank
block girdle
type-r oil pump
type-r water pump
moroso oil pan
eagle vtec conversion kit
now i am thinking or geting a b16a1 head port and polished and doing type-r cams and a valve train kit.
is the b16 head a good idea?
after that im going to need to know what tranny i should use for this set up.
im only going to run like 5-6 lbs. of boost. and maybe 25 shot of nitrious that should be fine for the stock sleeves. lemme know what you think.
Old Jan 10, 2005 | 12:29 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: b20 vtec turbo... what head? (b20vtechatch)
you know when using ls pistons and a vtec head the compression is lower than a ls stock .
Old Jan 10, 2005 | 12:36 PM
Rod.'s Avatar
Default Re: b20 vtec turbo... what head? (DumpeDc2)
gsr....b16..type r heads are all good heads. Anyone would be a good choice
Old Jan 11, 2005 | 08:58 AM
b20vtechatch
Guest
Posts: n/a
ls pistons are 81mm my friend 8.5 is fine and im geting a head gasket too.
Old Jan 11, 2005 | 09:00 AM
Slick GS-R's Avatar
Man oh man, you should have sleeved it! The bug will bite you to turn the boost up, trust me! But either way, B16 or B18C head will be good
Old Jan 11, 2005 | 09:03 AM
b20vtechatch
Guest
Posts: n/a
Default Re: b20 vtec turbo... what head? (Slick GS-R)
i know but i think ill get enough hp out of 6 psi. i want to build a b18b sleeved with like 15 psi ill have fun later on with that project
Old Jan 11, 2005 | 09:04 AM
joepiscapo_83's Avatar
^^^what slick-gsr said^^^
ls blocks are better for boost if your going stock sleeves....
and a b16a head would be what you wanted
Old Jan 11, 2005 | 09:05 AM
b20vtechatch
Guest
Posts: n/a
Default Re: b20 vtec turbo... what head? (v8killr83)
yea but im only boosting 6 psi thats fine for stock sleeves and its going to be a sunday car
Old Jan 11, 2005 | 09:22 AM
AngelTeg's Avatar
ignore the haters... check my sig
good luck... very similar to my setup... and you're local, too wow... I'm gonna have to keep in touch.
-Mike
Old Jan 11, 2005 | 09:34 AM
Chunty Butt Kevin's Avatar
from what i read, stock sleeves on a B20 isn't a good idea for boost.
Old Jan 11, 2005 | 09:52 AM
B20TDC2's Avatar
gsr head is what i run on my b20 , flows great but i have heard that b16a heads flow better. stock b20 sleeves hold up good on moderate boost levels mine held 12lbs for a while before i burned a hole in piston #4. if only 6 lbs should be ok but i would suggest sleeveing the block if you even think about turning it up! my stock b20 #s 312whp 300trq @12lbs with wack *** vafc hack. check my sig thats on a built block.
Old Jan 11, 2005 | 11:26 AM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch &raquo;</TD></TR><TR><TD CLASS="quote">i have my block all set up........
b20b honed
atc bearings
block gaurd
b20 crank
block girdle
type-r oil pump
type-r water pump
moroso oil pan
im only going to run like 5-6 lbs. of boost. and maybe 25 shot of nitrious that should be fine for the stock sleeves. lemme know what you think.</TD></TR></TABLE>
no offense... i mean your set up will work fine... but for less money you could have gotten a stock b18b and boosted it and probably make more power then you will with your b20vtec on 6 psi... but good luck with it... and i think a gsr head will work great with that set up... but like someone else said you shoud have sleeved that block.
Old Jan 11, 2005 | 11:31 AM
respectblades's Avatar
Default Re: b20 vtec turbo... what head? (J337_UNIT)
the difference in hp that the stock head will make will not effect what your doing with it
gsr heads higher comp
b16a flow better
itr head is the same casting as a b16a
your gonna fine with anyone of these
Old Jan 11, 2005 | 12:44 PM
beerbongskickass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch &raquo;</TD></TR><TR><TD CLASS="quote">i know but i think ill get enough hp out of 6 psi. i want to build a b18b sleeved with like 15 psi ill have fun later on with that project</TD></TR></TABLE>
A b20 on 6psi will be ******* weak for a turbo b-series motor. Oh and you don't need to sleeve the block to run 15psi. That would be a complete waste of money.
Old Jan 17, 2005 | 12:00 PM
b20vtechatch
Guest
Posts: n/a
do you know what your talking about i had a b18b 6psi and i did run fine but the set up i have now is alot better. b20 vtec tuned will give me like 200-220hp. turboing it will give it at least 80-110hp. you do the math.
by the way i got the b16a1 head port and polished with 3 angle valve job and type-r cams thanks.
Old Jan 17, 2005 | 09:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch &raquo;</TD></TR><TR><TD CLASS="quote">do you know what your talking about i had a b18b 6psi and i did run fine but the set up i have now is alot better. b20 vtec tuned will give me like 200-220hp. turboing it will give it at least 80-110hp. you do the math.</TD></TR></TABLE>
I do know what I am talking about. With those low compression 8.5:1 pistons, your B20/Vtec tuned won't put down close to 200-220hp... maybe if you had high compression pistons it would. I am also guessing you won't gain 80-110hp with only 5-6psi, it's probably going to take more boost than that.
Old Jan 18, 2005 | 09:23 AM
b20vtechatch
Guest
Posts: n/a
Default Re: b20 vtec turbo... what head? (beerbongskickass)
i've personaly seen this set up done and have seen the numbers so i think it will be fine
93h2beg
Feb 10, 2013 10:02 PM
SiRstewart99
Oct 15, 2012 05:43 AM
o'malley_808
Oct 29, 2006 01:08 PM
b20vtechatch
Apr 18, 2005 01:32 PM
9900RPM
Jan 8, 2005 02:26 PM
