what could a bad iac be
Old Jan 9, 2005 | 08:21 PM
boostng r's Avatar
a
Default what could a bad iac be
what can it cause the car to do
14 IAC (EACV) - idle air control valve
i changes out my injectors to 345 cc prelude with
all of a sudden my car acts werid verry low idle at cold starts it wont hold idel when i drive it the throttle is verry jerkey
please i mean please some one help me
when i hold the idle around 1500 rpms the motor seems like it has a big *** vaccum leak it the rpms jump when i am holding idle at 1500 it so ****** weird
Old Jan 9, 2005 | 08:23 PM
jlacoy82's Avatar
71.192.16.183
..........A bad IACV could be..........a bad IACV, its the black thing on the back of your intake manifold with a wire plug and a few vacuum hoses connected to it. I think it can sometimes be fixed by just pulling it off and cleaning it out?
Old Jan 9, 2005 | 08:24 PM
boostng r's Avatar
a
Default Re: (jlacoy82)
i know where its at and it has two water lines going to it no vaccum thanks any more people
Old Jan 9, 2005 | 08:33 PM
boostng r's Avatar
a
Default Re: what could a bad iac be (b16coupe4)
ttt
Old Jan 9, 2005 | 08:59 PM
boostng r's Avatar
a
bump
Old Jan 9, 2005 | 09:34 PM
.BigSexy's Avatar
most hood white kid
i have the same problem, except i don't have a jerky throttle problem, I have a bouncy idle at lower RPM's a guy on here said reset your ECU, and clean out the IACV, but other than that, I have no clue, here is the thread where he told me to reset your ECU if you don't know how, I personally didn't know how, so it helped me.
https://honda-tech.com/zerothread?id=1102355
Old Jan 9, 2005 | 09:51 PM
ccivic's Avatar
... You can't run those 345cc injectors with your stock (240cc most likely) map! Fuel maps don't work by cc's, they work by duty cycles. If you have 75% duty cycle on a 240cc injector, it's going to put ~180cc's of fuel in... but with that same map, with the 345cc injector you're going to be dumping ~258.75cc's of fuel in.. more than your stock injectors can even flow!! Your car is most likely running very rich! Get it tuned.
Old Jan 9, 2005 | 10:50 PM
.BigSexy's Avatar
most hood white kid
Default Re: what could a bad iac be (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">... You can't run those 345cc injectors with your stock (240cc most likely) map! Fuel maps don't work by cc's, they work by duty cycles. If you have 75% duty cycle on a 240cc injector, it's going to put ~180cc's of fuel in... but with that same map, with the 345cc injector you're going to be dumping ~258.75cc's of fuel in.. more than your stock injectors can even flow!! Your car is most likely running very rich! Get it tuned. </TD></TR></TABLE>
this guy knows what he is talking about...lol
Old Jan 10, 2005 | 06:19 AM
boostng r's Avatar
a
tttttt
joelmatt89
15
Nov 4, 2009 05:27 PM
averyvm
17
Jan 17, 2007 11:51 AM
hondachris1994
10
Feb 25, 2006 02:37 PM
94SHOWLS
Feb 17, 2005 12:31 PM
s2k
Feb 25, 2003 06:50 PM
