????? Which Evap Purge Solenoid for Swap ??????
Old Jan 9, 2005 | 06:11 PM
jmk2888's Avatar
Default ????? Which Evap Purge Solenoid for Swap ??????
Does anyone know if I need a OBDI or OBDII ?
https://honda-tech.com/zerothread?id=1109649
Old Jan 9, 2005 | 07:23 PM
jmk2888's Avatar
Default Re: ????? Which Evap Purge Solenoid for Swap ?????? (jmk2888)
ttt
Old Jan 9, 2005 | 09:28 PM
jmk2888's Avatar
Old Jan 9, 2005 | 10:26 PM
skunk2finatic's Avatar
don't need it.....get rid of it
Old Jan 10, 2005 | 10:48 AM
jmk2888's Avatar
Default Re: ????? Which Evap Purge Solenoid for Swap ?????? (skunk2finatic)
I want it to pass the Ref.
Old Jan 10, 2005 | 06:59 PM
jmk2888's Avatar
up
Old Jan 12, 2005 | 11:56 AM
jmk2888's Avatar
ttt
Old Jan 12, 2005 | 04:30 PM
lazynok's Avatar
run it all as obd1 w/ a usdm gsr ecu ond1
Old Jan 12, 2005 | 09:11 PM
jmk2888's Avatar
Default Re: ????? Which Evap Purge Solenoid for Swap ?????? (lazynok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazynok &raquo;</TD></TR><TR><TD CLASS="quote">run it all as obd1 w/ a usdm gsr ecu ond1</TD></TR></TABLE>
Thanks for the reply, that is what I thought as well.
So a 1995 GSR OBD I Solenoid would do, right?
Old Jan 12, 2005 | 10:11 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the reply, that is what I thought as well.
So a 1995 GSR OBD I Solenoid would do, right? </TD></TR></TABLE>
they're all the same. obd1, ob2. just use the one that came stock on your car.
Old Jan 12, 2005 | 11:29 PM
carsaregood's Avatar
Default Re: ????? Which Evap Purge Solenoid for Swap ?????? (dantastic)
can you pass a type r swap in an obd1 car? I'm not sure if you can. As i understand it, the engine has exist in obd1 form for it to pass for you. if it is an obd2 motor, but has an obd1 equivalent, you can just set it up as obd1.
I just did this. I have a '99 gsr swap in a '95 civic. I ghetto-rigged an obd1 evap solenoid from I think a d16z6. I just found a spot on the manifold to mount it, wired it to pin A20, and ran the vacuum lines to it. I had to put in a vacuum T because there are no extra ports on the manifold. The obd2 evap system would not have worked unless i wanted to add a lot more sensors.
I passed the ref on monday. goodluck!
daf
20
Dec 20, 2006 06:31 AM
TuCKiNaLL4s
May 2, 2005 11:16 AM
escape2me
Feb 23, 2005 11:59 AM
OneFastGsr
Sep 17, 2003 06:24 PM
