f22b ecu question
i'm getting ready to buy a jdm f22b DOHC to replace my usdm f22a1 motor and i was wondering if i could use the usdm f22a1 ecu for the f22b or do i need to get a h23 ecu to run it. any help would be great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iCe_2x »</TD></TR><TR><TD CLASS="quote">why the s-afc? to lean it down a bit?</TD></TR></TABLE>
most likely if needed, basically it's similar..but not the right ecu so it makes sense to get a fuel adjustment tool
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rabbit94ludes »</TD></TR><TR><TD CLASS="quote">aight thanx guys</TD></TR></TABLE>
i have a feeling that using a h23 ecu on a f22b is going to yeild less power than it would make w/ its standard ecu.
japan has higher octane gas than here in the states... therefore it is possible that the f22b's ecu has a more aggressive ignition/fuel map program. which in turn, might explains why a 2.2L engine w/ 9.2:1 comp. makes 160 hp. keep in mind that f22b is basically a h23 w/ a 85 mm bore.
Modified by SUB-0 H23 at 12:23 AM 1/10/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUB-0 H23 »</TD></TR><TR><TD CLASS="quote">
Modified by SUB-0 H23 at 12:23 AM 1/10/2005</TD></TR></TABLE>
Japanese gas is not that much higher 100 ROM (Reasearch Octane) is a higher rating than US (R+M)/2 method, which is the average of research (high) and mechanical octane rating (lower). I can't remember but 100 is more like 94, which I agree is not necessarily available everywhere. Just some info...
SUB-0 H23
Dec 30, 2004 09:41 AM
