D15b8 not cat!? exhaust question
Old Jan 9, 2005 | 03:53 PM
StreetEG's Avatar
Default D15b8 not cat!? exhaust question
got a cx, and grabbed some suspension and wheels....then test drove it, and the exhaust fell off. Classy. Didnt want to replace it till i got the swap so that i could just have everything figured out then and there but i had no choice.
Picked up some Worldsport 2 and bolted the rear section up only to find that there is no cat to bolt it up to. This means 2 things.
1. I have a muffler shop weld a flange onto the stock piping where the cat is supposed to be
2. get a cat.
My Questions
Will a cat that i get now bolt right up to a b16 swap.
Are all cats the same length...i.e. can i just pick up a high flow for my car, and use it with the b
Thanks
Eric
Old Jan 9, 2005 | 04:08 PM
drewbie*'s Avatar
Default Re: D15b8 not cat!? exhaust question (StreetEG)
heh.. the cat is right after your exhaust manifold not on the exhaust piping
Old Jan 9, 2005 | 04:13 PM
StreetEG's Avatar
Default Re: D15b8 not cat!? exhaust question (Drew95eg)
still lost...
under the car... there is a pipe coming off the header, that goes about 10 inches before where the worldsport is supposed to connect... ill take pictures tomorrow in the daylight
btw ill be a noob at postin pics...where should i host?
Old Jan 9, 2005 | 04:17 PM
drewbie*'s Avatar
if you take a look at your exhaust manifold you will notice a little chubby in the piping.. following that is a little downpipe
basically the cx stock piping is a bit longer then the si because on the si the cat comes after the header, where on the vx/cx the head is really 3 pieces..exhaust mani, cat, downpipe
Old Jan 9, 2005 | 04:21 PM
ScubaStevo80's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetEG &raquo;</TD></TR><TR><TD CLASS="quote">still lost...
btw ill be a noob at postin pics...where should i host?</TD></TR></TABLE>
I bought an Si exhast mani and cat to mate up to my prospec exhaust. The cx/dx exhaust has the cat up high and a two bolt flange on the downpipe that would meet the catback. You need a threebolt flange like a normal undercar cat would. I'd say pickup a used ex/si header and cat for your car... should cost less than $75 total, or a good header and used cat.
Old Jan 9, 2005 | 04:34 PM
drewbie*'s Avatar
Default Re: D15b8 not cat!? exhaust question (VolpeOwnsU)
i have the header and downpipe if you want one.. then just pick up a testpipe or hi flow cat
Old Jan 9, 2005 | 04:44 PM
StreetEG's Avatar
I think im gonna take it to a local muffler shop and have them weld a flange to bolt the worldsport up to... This is only temporary untill i get the swap...i just couldnt believe it when i didnt see a cat.
I dont want to dump more money then i have to in to that B8...thank you for all the quick replys
Eric
91blackEF
Jan 10, 2009 02:42 PM
I AM WEASEL
Mar 3, 2008 10:28 PM
haophat
Nov 17, 2004 08:56 AM
Pfieff
Sep 12, 2003 01:59 PM
LuderCriS
Mar 15, 2002 04:44 AM
