h22 head on h23 bottom end
Old Jan 9, 2005 | 07:39 AM
civicsiluver's Avatar
Default h22 head on h23 bottom end
alright the other night while out street racing everyone got on the topic of this swap i hear that if you take the h22 vtec head and put it on the h23 non vtec bottom end you can make some crazy power and tq is this true? i also hear that it is as simple as the head swap is this true? no oil lines to tap or anything? is this setup as unreliable as the ls/vtec b20/vtec? is it even possible? any help would be appreciated
Old Jan 9, 2005 | 08:03 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: h22 head on h23 bottom end (civicsiluver)
yes it is possible and done many times. It is almost the same thing as doing lsvtec or b20vtec but i don't know if you have to run an oil line or not. And they do make good power, thinking of doin it in my coupe
Old Jan 10, 2005 | 10:23 AM
PrettyLude's Avatar
its the pretty same concept as lsvtec, you will need the oil lines
Old Jan 10, 2005 | 12:27 PM
hybridpatient95's Avatar
Default Re: (PrettyLude)
yea its the same thing as the other frankenstein setups you need to change your timing belt and oil pump and water pump... and you need oil lines.. and if done right you;ll be shitting on ls vtecs and b20vtecs...
Old Jan 13, 2005 | 08:21 AM
Default Re: (frankenfiend 04)
does anyone know where i can find some legit info on this swap like maybe someone who specializes in it or someone who has done it?
Old Jan 13, 2005 | 09:12 PM
PrettyLude's Avatar
look on golden eagle's webpage, they sell the complete kit, as well as lightingmotorsports.com
Old Jan 17, 2005 | 10:00 PM
bigbacon2's Avatar
u can do it i remember someone did a write up on here a year or so ago maybe a lil longer there is a list of **** u have to get to make it work its not as easy as it seems
Old Jan 17, 2005 | 10:12 PM
slomofo's Avatar
GDD Member
https://honda-tech.com/zerothread?id=510617
https://honda-tech.com/zerothread?id=896304
Las BAYgas
Jan 12, 2005 03:03 PM
HumanH23
Dec 2, 2004 07:19 AM
mthrfckrz
Aug 15, 2004 01:51 PM
ensracer
Mar 1, 2004 06:21 PM
dragonrcr
Dec 11, 2002 08:15 PM
