00ls into 97ex.. which a/c to use???
Old Jan 8, 2005 | 03:23 PM
flipkid's Avatar
Default 00ls into 97ex.. which a/c to use???
im swapping in a 00ls motor into my 97 civic ex... which a/c do i use? the one from the integra or the civic?
Old Jan 8, 2005 | 05:44 PM
b20_ed's Avatar
Default Re: 00ls into 97ex.. which a/c to use??? (flipkid)
the one from the integra, cause the bolts wont line up if you use the civic one.
Old Jan 9, 2005 | 03:55 PM
97civicdx's Avatar
Doesnt the p-54 ac bracket apply here too, using the civic ac compressor?
Old Jan 9, 2005 | 08:27 PM
Mr Boston's Avatar
Get a P54 AC bracket and reuse your civic AC
Old Jan 9, 2005 | 09:37 PM
b 1 6 a 2's Avatar
Call me ghetto, but Im using the a/c compressor off my d16 on the b16. The bolts dont line up, but its held on tightly with 2 bolts on the right side. Everything works fine, but I would like to fix the problem.
I want to know more about this P54 bracket and where can i get this? I tried a quick ebay search but couldnt come up with anything.
I also have a B16 a/c compressor for backup. The reason why the b compressor didnt get installed was because I didnt want the freon to escape and the ac lines werent available.
Is it true that the a/c off the ex isnt long enough to work? It wasnt done at the time because we didnt have the compressor.
Sorry for the threadjack, but it can relate to you.
Edit:
Speaking of the P54 bracket, isnt that from a dohc del sol? I heard of this a very long time ago. Someone please confirm. This will let you retain the D16 compressor, correct?
Modified by [civic] at 10:59 PM 1/9/2005
Old Jan 10, 2005 | 01:54 AM
97civicdx's Avatar
Default Re: ([civic])
Yes
Hobbez
Honda Civic (2006 - 2015)
May 9, 2009 10:44 PM
g23_ej1
May 26, 2008 04:12 AM
DetainedCivic
Jul 17, 2006 04:54 PM
bullock
Sep 12, 2004 07:09 PM
davken1102
Mar 18, 2004 09:52 PM
