Integra AC compressor work in a 98' civic ex?
Re: Integra AC compressor work in a 98' civic ex? (g23_ej1)
It will not work. Will not bolt up to the bracket, will not connect properly to the factory AC lines in your car.
Re: Integra AC compressor work in a 98' civic ex? (3gcvcd16)
Sure isn't. Even if there WAS a bracket, what would the point be? You'd have to spend the money on the bracket and AC lines. It would be cheaper to just buy another D series compressor. If this was a B swapped car, you could simply use a P30 bracket to use the Integra compressor then you'd need to make some AC lines fit the compressor. Since it's a D series, you are pretty much stuck using a D series compressor.
