LCA Bolt
Old Jan 8, 2005 | 02:25 PM
CRseXy's Avatar
Default LCA Bolt
hey yall, Well in an atempt to Remove the Axles out of my car, I manged to fug up my Bolt that connects to the Knuckle, It has a Castle nut on it. how would I go about replacing it??? thanks.
Old Jan 8, 2005 | 03:43 PM
CRseXy's Avatar
Default Re: LCA Bolt (pogiTSI)
wow, this forum Goes fast.
Old Jan 8, 2005 | 03:44 PM
Rostr02's Avatar
what ecactly did you do?
Old Jan 8, 2005 | 03:45 PM
CRseXy's Avatar
Default Re: LCA Bolt (Rostr02)
the threads on it are fugged. Stripped.
Old Jan 8, 2005 | 03:47 PM
wtsexton's Avatar
Are you talking about the lower ball joint? If so just replace the ball joint.
Old Jan 8, 2005 | 03:48 PM
CRseXy's Avatar
Default Re: (wtsexton)
yeah, the lower ball joint, sorry. does it need to be pressed in????
Old Jan 8, 2005 | 07:30 PM
wtsexton's Avatar
Default Re: (pogiTSI)
Yes and no. I've placed them back in with a rubber hammer and a piece of wood. Just grease the sides up and take your time.
Old Jan 8, 2005 | 07:50 PM
abnaasefmb's Avatar
yeah take the knuckle off and take it to a shop and have them pressed out and new ones pressed back in. there is a snap ring on the ball joint that will need to be taken off before this is done. next time your working on ball joints after you take the nut off put a piece of hose over the bolt to make sure the threads don't get messed up while your working on you car.
Old Jan 8, 2005 | 11:37 PM
CRseXy's Avatar
Default Re: (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">yeah take the knuckle off and take it to a shop and have them pressed out and new ones pressed back in. there is a snap ring on the ball joint that will need to be taken off before this is done. next time your working on ball joints after you take the nut off put a piece of hose over the bolt to make sure the threads don't get messed up while your working on you car. </TD></TR></TABLE>
Anyone know how much it would cost?? thanks.
Old Jan 9, 2005 | 12:04 AM
STG3PWR's Avatar
about 10-15 bucks a side, hammer ^^
Old Jan 9, 2005 | 05:03 AM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
call a shop and ask if you really wanna know. no one works for 15 bucks anymore. try 40.
Old Jan 9, 2005 | 12:23 PM
abnaasefmb's Avatar
Default Re: (mike_belben@yahoo.com)
i'm not to sure about the hammer. i did all the bushings and ball joints on my front end last weekend. i have a 12 ton press and those things were a pain in the *** to get out and in. the wheel bearings were worse.
Old Jan 9, 2005 | 02:10 PM
wtsexton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">i'm not to sure about the hammer. i did all the bushings and ball joints on my front end last weekend. i have a 12 ton press and those things were a pain in the *** to get out and in. the wheel bearings were worse. </TD></TR></TABLE>
Trust me, it if you don't go wacking the **** out of it then you'll be fine.
There is no need for a press when it comes to ball joints now wheel bearings sure as hell require them.
Old Jan 10, 2005 | 10:49 PM
STG3PWR's Avatar
dude at front desk told me 15 bucks, one side, took it and did it himself. probably kept the 15 for himself too but 40?! for that. i dont think so
kenzo42
Sep 5, 2013 05:45 AM
EX-JAY
Oct 25, 2004 02:46 PM
tuphatt
11
Sep 15, 2004 12:10 AM
speed_racer012
32
Mar 12, 2004 02:58 PM
g2man
Nov 27, 2003 09:53 PM
