mini-me wiring problem
I have a 93 Del Sol S and in the process of finishing a z6 head swap. Problem is this...why do I have a map sensor on top of the throttle body with no plug for it? The old head (B7) had no sensor there, so no wire. What do I do?
Your del sol probably has the map sensor mounted on the fire wall.
As long as that is still plugged in and youve got a vacume line running to it, youre ok.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">Your del sol probably has the map sensor mounted on the fire wall.
As long as that is still plugged in and youve got a vacume line running to it, youre ok.</TD></TR></TABLE>
Yup.
Yup.
92integra-R
Aug 17, 2008 06:20 AM
mighty_max99
May 31, 2004 09:27 PM
