mini-me wiring problem
Old 01-08-2005, 01:15 PM
chinslip's Avatar
Default mini-me wiring problem
I have a 93 Del Sol S and in the process of finishing a z6 head swap. Problem is this...why do I have a map sensor on top of the throttle body with no plug for it? The old head (B7) had no sensor there, so no wire. What do I do?
Old 01-08-2005, 01:33 PM
Slopoke's Avatar
Default Re: mini-me wiring problem (chinslip)
Your del sol probably has the map sensor mounted on the fire wall.
As long as that is still plugged in and youve got a vacume line running to it, youre ok.
Old 01-08-2005, 01:41 PM
Br1anPham's Avatar
Default Re: mini-me wiring problem (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">Your del sol probably has the map sensor mounted on the fire wall.
As long as that is still plugged in and youve got a vacume line running to it, youre ok.</TD></TR></TABLE>
Yup.
Old 01-08-2005, 10:28 PM
friz's Avatar
I disagree. It is much better to use the one on the TB. Just unplug the one on the firewall and route the plug to the one on the TB.
mrspeedy69
04-25-2010 02:55 PM
92integra-R
08-17-2008 06:20 AM
gilligan354
04-29-2006 07:42 PM
mighty_max99
05-31-2004 09:27 PM
Quick Reply: mini-me wiring problem
