t3/to4e 50/63ar or sc50?
Old Jan 8, 2005 | 10:53 AM
NotPhilTran's Avatar
Default t3/to4e 50/63ar or sc50?
b16 with love fab shorty, tial 38 wastegate.
soon to be 9:1 pistons and rods. shooting for 350whp give or take.
where can i get the cheapest deal on these turbos?
currently looking at cheapturbo.com
dont know where i can buy the sc 50.
Old Jan 8, 2005 | 11:23 AM
01geeser's Avatar
New User
Default Re: t3/to4e 50/63ar or sc50? (NotPhilTran)
http://fast-turbo.com
Old Jan 8, 2005 | 11:45 AM
b16sedan's Avatar
Default Re: t3/to4e 50/63ar or sc50? (01geeser)
If by "50/63ar" you mean 50-trim with a .63 A/R exhaust, then both turbos are basically the same thing. I've heard PTE's exhaust housings flow slightly better than a typical turbonetics or whatever housing, but they're 99.99% the same turbo.
Old Jan 8, 2005 | 12:23 PM
Default Re: t3/to4e 50/63ar or sc50? (b16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">If by "50/63ar" you mean 50-trim with a .63 A/R exhaust, then both turbos are basically the same thing. I've heard PTE's exhaust housings flow slightly better than a typical turbonetics or whatever housing, but they're 99.99% the same turbo.</TD></TR></TABLE>
thanks for the response. ill pick up the 50 trim 63 ar t3/to4e because its 589 from cheap turbo, and the sc is about 700. thank you.
Old Jan 8, 2005 | 12:38 PM
b16sedan's Avatar
The cheapturbo one comes standard with a 270 degree thrust bearing, i'd opt to upgrade it to the 360 degree bearing.
Old Jan 8, 2005 | 12:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">The cheapturbo one comes standard with a 270 degree thrust bearing, i'd opt to upgrade it to the 360 degree bearing.</TD></TR></TABLE>
explain yourself
me=turbo noob.
Old Jan 8, 2005 | 01:58 PM
Blackack26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotPhilTran &raquo;</TD></TR><TR><TD CLASS="quote">
explain yourself
me=turbo noob.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=616030
Old Jan 8, 2005 | 04:36 PM
DefiantGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotPhilTran &raquo;</TD></TR><TR><TD CLASS="quote">explain yourself
makes the turbo last longer.
Old Jan 8, 2005 | 07:14 PM
DefiantGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotPhilTran &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the response. ill pick up the 50 trim 63 ar t3/to4e because its 589 from cheap turbo, and the sc is about 700. thank you.</TD></TR></TABLE>
You can find almost brand new SC50s for like 550-580. Just be patient.
Wyatt87
Nov 21, 2010 05:23 PM
spoolin turbo s
Oct 4, 2007 10:37 AM
MIKES
Jul 12, 2005 10:10 PM
B16CRXT
Dec 30, 2004 01:08 PM
DA6righthand
May 28, 2004 11:20 PM
