need help on choosing pistons and rods and sleeving company
Old Jan 7, 2005 | 07:26 AM
tspkenneth's Avatar
Default need help on choosing pistons and rods and sleeving company
i need help on what pistons an rods to get and possibly a re-sleeve job. I have a b18b motor and wnat to make around 350 hp. I want to go with arias pistons and eagle rods. How do i figure out how big of bore size to get for the pistons? And what is the biggest bore size a stock sleeve can handle? Please help so i can figure out if i need to resleeve or just use stock sleeves with the new piston and rod setup. I would most likely get a block gaurd if i dont resleeve..thanks
Old Jan 7, 2005 | 07:42 AM
BoostR41's Avatar
Default Re: need help on choosing pistons and rods and sleeving company (tspkenneth)
Golden Eagle sleeves are the best IMO
Old Jan 7, 2005 | 08:27 AM
Darton Sleeves's Avatar
You can send it to us here in California to re-sleeve or to our new shop In Indiana @888-877-8484
Old Jan 7, 2005 | 08:29 AM
PrettyLude's Avatar
earl can fix u up with cp pistons, pauter rods, and benson sleeves, and great customer service
Old Jan 7, 2005 | 02:39 PM
tspkenneth's Avatar
Default Re: (PrettyLude)
what would be the best compression ratio piston and bore size be for my setup?
Old Jan 7, 2005 | 03:05 PM
earl's Avatar
81.5mm max on a stock ls block and 9-1 on the pistons.
Sleeved block you can start at 83mm
Old Jan 7, 2005 | 03:12 PM
Default Re: need help on choosing pistons and rods and sleeving company (earl)
Go big or go home...j/k
Sleeve the block and go with a 84mm bore for best results...
Old Jan 7, 2005 | 03:16 PM
rextec's Avatar
you dont need sleeves for 350hp, with a good tune. bore your stock sleeves .20 over to keep them a little on the thick side to hold the boost.
Old Jan 7, 2005 | 03:24 PM
tspkenneth's Avatar
Default Re: (rextec)
i would love to go big but there's always the money issue ...i've ran a 12.8 with my b18b hatch on 7psi....but its not fast enough..i need more
Old Jan 7, 2005 | 03:46 PM
SpoolnG2's Avatar
Default Re: (tspkenneth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">earl can fix u up with cp pistons, pauter rods, and benson sleeves, and great customer service</TD></TR></TABLE>
....couldnt have said it better myself. As for c/r i'd go with 9.5:1
93delsolJDM
Feb 13, 2011 11:25 PM
JDM turbo DC
Nov 9, 2005 12:55 PM
b_jamin
Mar 19, 2004 02:55 AM
93B17A
Feb 4, 2002 03:08 PM
downpipe
Dec 14, 2001 12:02 PM
