Wastegate banjo fittings?
Old Jan 7, 2005 | 06:47 AM
turboteg2nv's Avatar
Default Wastegate banjo fittings?
Does anyone know where to find replacement banjo fittings for a TiAL wastegate? I bought one used and it came with some ghetto connectors.
Old Jan 7, 2005 | 08:29 AM
Finland's Avatar
Default Re: Wastegate banjo fittings? (turboteg2nv)
throw that **** in the garbage. I pulled the housing off, and re-tapped the holes to 1/8"npt, then you will have a lot of freedom in deciding what fittings you want to use.
It's easy and only takes a few minutes. PS, make sure you don't try to tap the holes with the gate assembled, you don't want metal shavings inside, they will damage the diaphragm.
Old Jan 7, 2005 | 11:13 AM
Default Re: Wastegate banjo fittings? (ForceFedDetroit)
Cool, thanks for the idea. Maybe that's why mine came with some different connectors; i'll have to check the pitch and find a new fitting.
rioninja
Aug 30, 2005 09:40 PM
smnowell
Feb 5, 2005 03:26 PM
SPOOLINmatt
Jan 12, 2005 07:51 AM
WEPN R
Mar 2, 2004 10:16 AM
stockgreencivic
Apr 6, 2003 06:32 PM
