valve Cover Installation
Old Jan 6, 2005 | 04:04 PM
wushubrian's Avatar
Default valve Cover Installation
Hey, I tried searching for valve cover installation and it didn't really come up with any good DIY tutorials. I was wondering if anyone could tell me or give me a link to a how to install a valve cover for a SOHC D16Y7 motor or any other similar motor. Also what would i need to install it. I know i would need a gasket. Anything else. Thank you and sorry if I missed it during a search. Thanks again.
Old Jan 6, 2005 | 04:17 PM
dctoast's Avatar
Default Re: valve Cover Installation (wushubrian)
it would be wise to use some hondabond or rtv on the side near the timing belt and the side near the dizzy
Old Jan 6, 2005 | 05:58 PM
alotawatts's Avatar
Default Re: valve Cover Installation (dctoast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dctoast &raquo;</TD></TR><TR><TD CLASS="quote">it would be wise to use some hondabond or rtv on the side near the timing belt and the side near the dizzy</TD></TR></TABLE>
Good advise.....on the the 90deg bends.
Old Jan 6, 2005 | 06:13 PM
TegoDC5's Avatar
Default Re: valve Cover Installation (alotawatts)
Make sure not to overtighten the bolts, they will break easily.
Old Jan 6, 2005 | 06:18 PM
sohcvtec1995's Avatar
Default Re: valve Cover Installation (Daddy Yankee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daddy Yankee &raquo;</TD></TR><TR><TD CLASS="quote">Make sure not to overtighten the bolts, they will break easily.</TD></TR></TABLE>
oh so tru.
Old Jan 6, 2005 | 08:27 PM
TegoDC5's Avatar
Just in case you break the bolts...saves you the trouble of searching and etc. Hope we helped you out!
https://honda-tech.com/zerothread?id=567450
Old Jan 6, 2005 | 08:57 PM
mp5o's Avatar
Default Re: (Daddy Yankee)
Buy a torque wrench. (I just spent 80 bucks on a craftsmans torque wrench...)
Old Jan 7, 2005 | 05:06 AM
wushubrian's Avatar
BUMP Still looking for a DIY installation guide. I have the idea on how to install it but I don't want to miss any steps. Any DIY guides out there on how to install a SOHC valve cover.
Old Jan 7, 2005 | 06:03 AM
dwnthehatch's Avatar
Pull out plug wires
Unbolt the valve cover.
Take off the valve cover.
Cover the head internals to heep out contaminates.
Clean the valve cover/head contact area.
Install 4 gasket onto plug holes. use Hondabond to seal them.
Install Valve Cover gasket, place honda bond in the corners.
Install valve cover.
Tighten bolts to 6 ft/lbs.
Insert plug wires.
Old Jan 7, 2005 | 06:05 AM
Sijray21's Avatar
Default Re: valve Cover Installation (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">Pull out plug wires
Insert plug wires.</TD></TR></TABLE>
label the wires when you pull them out incase you can't tell which one's they are... you do NOT want to mess up the firing rotation.
hatchinprogress
17
Jul 18, 2005 07:55 PM
01ITR#173DC2ning
Feb 11, 2005 08:35 PM
alotawatts
Nov 30, 2004 03:46 PM
Mark Finley
Sep 7, 2004 12:35 AM
brcivic411
Dec 19, 2003 12:37 PM
