E-Brake
Old Jan 6, 2005 | 12:07 PM
Teggys1ClnDA's Avatar
Default E-Brake
ok, people is it just my car or do your e-brakes suck in your car too? i have to pull it up alllllll the way just to get it to work.. just curious. any ideas?
Old Jan 6, 2005 | 12:25 PM
B20badboy's Avatar
Default Re: E-Brake (98CivicChik)
You might need new brakes in the rear or you might need to adjust them.
Old Jan 6, 2005 | 12:42 PM
alotawatts's Avatar
How long have you owned the car ? Did the slack come on slowly over time.....would be normal. Check rear shoes ? Self adjusting rear brake wheel is a little tricky if you don't undertand it etc. You adjust the hand brake lever by removing the console.
Old Jan 6, 2005 | 12:46 PM
Inspector Gadget's Avatar
Default Re: E-Brake (alotawatts)
Take the e-brake cover off or armrest and adjust it. I only have to pull mine up a few inches and its fine.
Old Jan 6, 2005 | 12:49 PM
SpoOoLin EK's Avatar
Default Re: E-Brake (Inspector Gadget)
you can tighten up a little screw right behind your e brake. you need to take off the plastic that covers it. its only 2 screws to undo it so u can get access to the back of the ebrake handle...
ShadowDaisy82
Honda Civic (2001 - 2005)
May 9, 2017 01:36 PM
cheapo23
Jun 2, 2010 09:28 PM
beastman@
Jul 15, 2008 09:32 AM
PreludePhill
May 5, 2006 07:22 AM
FourthGenHatch
Apr 3, 2003 01:48 PM
