I Think This Goes Here... Question About Putting Engine on Stand
Old Jan 6, 2005 | 10:45 AM
BigPlansNoMoney's Avatar
Default I Think This Goes Here... Question About Putting Engine on Stand
I know I either want to start a D-Series or B-Series build up on the weekends, not sure yet.
My question is what engine stand should I get? Are most of them universal so they will hold all styles and sizes of engines (E.g. hold a Chevy big block one weekend then a B16 the next)?
Also, what weight tolerance should I get? I might eventually want to do a 5.0 swap in my 93 LX, so anyone have an idea how much one of those weighs...?
Old Jan 6, 2005 | 01:00 PM
notstock93's Avatar
Default Re: I Think This Goes Here... Question About Putting Engine on Stand (Justin_Bradley)
The tolerances will be listed on the stand description.
Yes they accept more than one "style" of engine- the legs that hold the engine swivel and turn to accommodate different patterns.
I used one for a Rocket 350 cid Olds engine and then used it to hold my b16 block
Old Jan 15, 2005 | 02:38 PM
thrty8street's Avatar
Default Re: I Think This Goes Here... Question About Putting Engine on Stand (notstock93)
hey where do i buy the bolts that hold up the engine on the engine stand?
mine is a 750lbs one from advance auto and it will be holding up my d-series
Old Jan 15, 2005 | 05:12 PM
THEUSED's Avatar
If you have them you can use your block to tranny bolts, or just go to your hardware store and pick up some of the same specs
Old Jan 15, 2005 | 08:25 PM
Default Re: (THEUSED)
So would I mount the bitch to the stand from the tranny side, meaning I'd have to take the tranny off of it?
Old Jan 15, 2005 | 08:52 PM
Turbogixxer's Avatar
Default Re: (Justin_Bradley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin_Bradley &raquo;</TD></TR><TR><TD CLASS="quote">So would I mount the bitch to the stand from the tranny side, meaning I'd have to take the tranny off of it?</TD></TR></TABLE>
Yes, you will have to take your transmission off to out your engine on a engine stand.
Old Jan 15, 2005 | 10:10 PM
engine_runner's Avatar
recomend to use new bolts if possible when mounting the engine to the stand and a empty tire under the engine when your not working on it
i had a case where i mounted a d series and couple bolts broke luckily there was a tire underneathe but still some damage was done to the oil pan
dzvero
Honda Civic (2006 - 2015)
Apr 1, 2018 10:26 AM
98vtec
Engine Machining & Assembly
65
May 30, 2014 06:55 AM
93preludeh22
May 25, 2008 09:06 PM
lilvietboy
20
Mar 10, 2008 11:56 AM
MyRex
Aug 31, 2005 11:21 AM
