this little thing fell out of my b16 head WHAT IS IT?!?!
Old Jan 5, 2005 | 06:02 PM
jbell's Avatar
Default this little thing fell out of my b16 head WHAT IS IT?!?!
Old Jan 5, 2005 | 06:03 PM
navin's Avatar
Default Re: this little thing fell out of my b16 head WHAT IS IT?!?! (jbell)
looks like a dowel pin?
jbell's Avatar
Default Re: this little thing fell out of my b16 head WHAT IS IT?!?! (navin)
its tiny.. like the size of a pea.
Old Jan 5, 2005 | 06:04 PM
k24a4kid's Avatar
I'm a Jackass
did you turn your head upside down?
chad's Avatar
Moderator
goes on the number 3 cam cap....between cap and head...where it feeds the oil for the cam caps...
Old Jan 5, 2005 | 06:05 PM
2lua's Avatar
guide pin or dowel pin for lining up the gasket, head to block.
Old Jan 5, 2005 | 06:19 PM
StErN's Avatar
Default Re: this little thing fell out of my b16 head WHAT IS IT?!?! (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">goes on the number 3 cam cap....between cap and head...where it feeds the oil for the cam caps...</TD></TR></TABLE>
What he said
Old Jan 5, 2005 | 07:51 PM
chad's Avatar
Moderator
Default Re: this little thing fell out of my b16 head WHAT IS IT?!?! (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">guide pin or dowel pin for lining up the gasket, head to block. </TD></TR></TABLE>
wrong try again....
Old Jan 5, 2005 | 08:38 PM
someforlight's Avatar
almost looks like the pin that holds the shift link in. who knows.
Old Jan 5, 2005 | 08:40 PM
jbell's Avatar
you sir are correct.
Old Jan 5, 2005 | 08:46 PM
paulzy's Avatar
yeap, and replace the o-ring seal that goes along with it while you're at it
Old Jan 5, 2005 | 09:15 PM
saywhat's Avatar
wrong try again....</TD></TR></TABLE>
No I think he is right, there were two on the b18 I was working on.
Old Jan 5, 2005 | 09:28 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: this little thing fell out of my b16 head WHAT IS IT?!?! (saywhat)
thats a shitty pic.. is it hollow? ide say either a dowel pin, or could... depending on how small it really is, could be the oil pins between each rocker arm, that engages VTEC and locks in the secondary lobe.
Old Jan 5, 2005 | 09:37 PM
StErN's Avatar
Default Re: this little thing fell out of my b16 head WHAT IS IT?!?! (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat &raquo;</TD></TR><TR><TD CLASS="quote">No I think he is right, there were two on the b18 I was working on.</TD></TR></TABLE>
Chad is right, if you look at the size of the dowel in the pic it is smaller than the two dowels you are referring to that are on the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">thats a shitty pic.. is it hollow? ide say either a dowel pin, or could... depending on how small it really is, could be the oil pins between each rocker arm, that engages VTEC and locks in the secondary lobe.</TD></TR></TABLE>
If you look closely it is hollow and small which resembles the dowels on the cam caps. Therefore it couldnt be the oil pistons that are in the rockers cause they are solid.
Old Jan 5, 2005 | 09:44 PM
Evs-One's Avatar
Solbros Owns Me
will people EVER read the responses before they psot? This is the LITTLE dowel pin, not the one for the head to block
Honda_Noob42385
10
Dec 30, 2007 08:14 PM
H22HondaCRX
Feb 22, 2007 12:51 PM
fastlimegreencivic
Feb 21, 2006 02:14 PM
StreetEG
78
Nov 27, 2005 04:58 PM
djtony5
Oct 18, 2005 02:29 PM
