Trouble with B16a Swap
Old Jan 5, 2005 | 05:50 PM
CiviCVuE's Avatar
Default Trouble with B16a Swap
I have a 94 SI hatch w/ B16a swap. The problem I am having is every now and then the motor will not start just turn over. I could just go to the gas station and the car would probably not start right back up. I have replaced the fuel pump, the dis. w/ MSD cap and Blaster SS Coil, new fuel filter, checked main relay and spark plugs. So if anyone has any info I would most appreciate it, I am getting ready to Freak. So any info would help.
Old Jan 5, 2005 | 08:33 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Trouble with B16a Swap (ridindeep2001)
Sounds like you have a loose connection somewhere. Double check your sensors' connection and make sure no signal/power wire is being accidentally grounded/knicked.
Old Jan 6, 2005 | 05:23 AM
CiviCVuE's Avatar
Default Re: Trouble with B16a Swap (NVturbo)
Thanks for the info I will check. It just makes no sense man
Bleakened
Jul 9, 2017 08:18 PM
Ueichi
Jul 28, 2012 05:38 PM
1991crxsib16a
23
Oct 4, 2009 04:38 PM
B16aEGx2
Apr 15, 2005 05:22 PM
TURBO
13
Jul 10, 2004 04:23 PM
