Motor swap problem
Motor swap problem
94 Del Slow swapped b16a3 with b16a
My car is not starting..Has fuel and ignition. I was talking to a technician from Acura and he said that the relays can go bad on most 94 Hondas and Acuras. How can I check to see if the relays are good or bad?
Any help or suggestion would be appreciated
Thanks
Thanks
Re: Motor swap problem (TURBO)
My sensor under the VTEC selenoid is broken would that keep it from not starting?
The spark plugs get drintched with fuel..
Re: Motor swap problem (steve_s)
man...ECU works got spark got fuel...I might be getting too much fuel though....but then again it should have combustion I've checked everything....Only thing I don't know how to check is sensors, but the car has no check engine light.
The car injested water so I don't know what sensors it could have damaged...so that might tell you something...
I am absolutely positive it's getting ignition and fuel. Does anyone have pics of their vacuum hose on their 94-95 acura integra or b16a? Can it be a bad EGR valve? or bad map sensor
Thanks
Modified by TURBO at 9:39 PM 7/9/2004
Modified by TURBO at 11:04 PM 7/9/2004
Modified by TURBO at 11:29 PM 7/9/2004
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO »</TD></TR><TR><TD CLASS="quote">Ok problems solved guys...thanks
Modified by TURBO at 11:24 PM 7/10/2004</TD></TR></TABLE>
oookay,
how bout u let peeps know what was wrong and what you did to fix it?
Everyone wants to help out, but it would be nice if you helped out right back by droppin the info.
ppl can learn from it.
congrats though
oookay,
congrats though
Re: Motor swap problem (Tad)
it was the distributor. It had a wire that was exposed. Thanks Guys. One thing I learn is that the Hondas are very simple. It's either fuel or spark.
darithS
23
07-11-2008 09:00 PM
sipolt89
12-09-2007 10:14 AM
