h23 crower cam specs! no more searching!
oem:
<U>duration @ .010"</U>
in:240 degrees
ex:240 degrees
<U>duration @ .050"</U>
in:183 degrees
ex:183 degrees
<U>lobe lift:</U>
in: .224"
ex: .224"
<U>gross lift:</U>
in: .414"
ex: .414"
stage .5 (stock replacement with similar specs to oem)
in:246 degrees
ex:250 degrees
in:190 degrees
ex:194 degrees
<U>lobe lift:</U>
in: .226"
ex: .218"
<U>gross lift:</U>
in: .418"
ex: .403"
Stage 1:
in:245 degrees
ex:251 degrees
in:193 degrees
ex:198 degrees
<U>lobe lift:</U>
in: .238"
ex: .228"
<U>gross lift:</U>
in: .440"
ex: .422"
stage 2 Turbo:
<U>duration @ .010</U>
in:245 degrees
ex:245 degrees
in:193 degrees
ex:193 degrees
<U>lobe lift:</U>
in: .238"
ex: .238"
<U>gross lift:</U>
in: .440"
ex: .440"
stage 2:
in:250 degrees
ex:250 degrees
<U>duration @ .050</U>
in:211 degrees
ex:210 degrees
<U>lobe lift:</U>
in: .241"
ex: .235"
<U>gross lift:</U>
in: .446"
ex: .435"
stage 3:
in:255 degrees
ex:255 degrees
in:215 degrees
ex:215 degrees
<U>lobe lift:</U>
in: .244"
ex: .244"
<U>gross lift:</U>
in: .451"
ex: .451"
stage 2+ you will need the spring and retainer upgrade
Modified by hOndafienD 04 at 11:04 PM 1/5/2005
in:240 degrees
ex:240 degrees
in:183 degrees
ex:183 degrees
<U>lobe lift:</U>
in: .224"
ex: .224"
<U>gross lift:</U>
in: .414"
ex: .414"
in:246 degrees
ex:250 degrees
in:190 degrees
ex:194 degrees
<U>lobe lift:</U>
in: .226"
ex: .218"
<U>gross lift:</U>
in: .418"
ex: .403"
Stage 1:
in:245 degrees
ex:251 degrees
in:193 degrees
ex:198 degrees
<U>lobe lift:</U>
in: .238"
ex: .228"
<U>gross lift:</U>
in: .440"
ex: .422"
stage 2 Turbo:
in:245 degrees
ex:245 degrees
in:193 degrees
ex:193 degrees
<U>lobe lift:</U>
in: .238"
ex: .238"
<U>gross lift:</U>
in: .440"
ex: .440"
stage 2:
in:250 degrees
ex:250 degrees
in:211 degrees
ex:210 degrees
<U>lobe lift:</U>
in: .241"
ex: .235"
<U>gross lift:</U>
in: .446"
ex: .435"
stage 3:
in:255 degrees
ex:255 degrees
in:215 degrees
ex:215 degrees
<U>lobe lift:</U>
in: .244"
ex: .244"
<U>gross lift:</U>
in: .451"
ex: .451"
cant give specs but brian at crower did the grinding for me to the specs i gave him its a mid and highend cam only pulls to 8grand with a stock nonvtec head no porting or any thing
sorry cant give specs , it wont free to find out what kinda power band i needed for dragracing and what my head will take
put it this way i went thru many sets of valve seals try to get it right
lol
lol
i dunno but i got the specs from some guys and its on a crower sheet...they even have a stock cam yet a little more aggresive....its a stage between oem and stage 1....so umm .5? lol i'll post that later.
I measured my STOCK cams as this:
stock 1993 H23A1 cams:
Measured at 0.050" lift.
Intake opening (BTDC)
-21° (so that is 21° ATDC)
Intake closing (ABDC)
24°
Duration: 183°
Exhaust opening (BBDC)
30°
Exhaust closing (ATDC)
-20° (20° BTDC)
Duration: 190°
Gross valve lift measured w/1.67 rocker ratio
Intake @ cold .003" clearance:
~0.370"
Exhaust @ cold .006 clearance:
~0.370"
24°
Duration: 183°
30°
-20° (20° BTDC)
Duration: 190°
~0.370"
~0.370"
Hi im looking to buy a pair of crower stage 1 camshafts, do u know if crower has any offical retailers or do they only sell direct. Becuase i tried looking for their prices and could not find any stores that sells h23 cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmaek »</TD></TR><TR><TD CLASS="quote">Hi im looking to buy a pair of crower stage 1 camshafts, do u know if crower has any offical retailers or do they only sell direct. Becuase i tried looking for their prices and could not find any stores that sells h23 cams.</TD></TR></TABLE>
http://www.google.com
itslogz
Nov 16, 2008 07:32 PM
