h23 crower cam specs! no more searching!
oem:
<U>duration @ .010"</U> in:240 degrees ex:240 degrees <U>duration @ .050"</U> in:183 degrees ex:183 degrees <U>lobe lift:</U> in: .224" ex: .224" <U>gross lift:</U> in: .414" ex: .414" stage .5 (stock replacement with similar specs to oem) <U>duration @ .010"</U> in:246 degrees ex:250 degrees <U>duration @ .050"</U> in:190 degrees ex:194 degrees <U>lobe lift:</U> in: .226" ex: .218" <U>gross lift:</U> in: .418" ex: .403" Stage 1: <U>duration @ .010"</U> in:245 degrees ex:251 degrees <U>duration @ .050"</U> in:193 degrees ex:198 degrees <U>lobe lift:</U> in: .238" ex: .228" <U>gross lift:</U> in: .440" ex: .422" stage 2 Turbo: <U>duration @ .010</U> in:245 degrees ex:245 degrees <U>duration @ .050"</U> in:193 degrees ex:193 degrees <U>lobe lift:</U> in: .238" ex: .238" <U>gross lift:</U> in: .440" ex: .440" stage 2: <U>duration @ .010</U> in:250 degrees ex:250 degrees <U>duration @ .050</U> in:211 degrees ex:210 degrees <U>lobe lift:</U> in: .241" ex: .235" <U>gross lift:</U> in: .446" ex: .435" stage 3: <U>duration @ .010</U> in:255 degrees ex:255 degrees <U>duration @ .050</U> in:215 degrees ex:215 degrees <U>lobe lift:</U> in: .244" ex: .244" <U>gross lift:</U> in: .451" ex: .451" https://honda-tech.com/forums/images/smilies/emthup.gif stage 2+ you will need the spring and retainer upgrade Modified by hOndafienD 04 at 11:04 PM 1/5/2005 |
Re: h23 crower cam specs! no more searching! (hOndafienD 04)
my lift still bigger then the stage 3's https://honda-tech.com/forums/images...s/emsmilep.gif
post the type of cams and specs https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (hOndafienD 04)
cant give specs but brian at crower did the grinding for me to the specs i gave him its a mid and highend cam only pulls to 8grand with a stock nonvtec head no porting or any thing
sorry cant give specs , it wont free to find out what kinda power band i needed for dragracing and what my head will take put it this way i went thru many sets of valve seals try to get it right https://honda-tech.com/forums/images...s/emsmilep.gif lol |
Re: (hOndafienD 04)
Thanks for that info https://honda-tech.com/forums/images/smilies/emthup.gif When did the turbo cam come out?!?!
i dunno but i got the specs from some guys and its on a crower sheet...they even have a stock cam yet a little more aggresive....its a stage between oem and stage 1....so umm .5? lol i'll post that later.
stage .5 specs as i will call them is up!
Re: (hOndafienD 04)
I measured my STOCK cams as this:
stock 1993 H23A1 cams: Measured at 0.050" lift. Intake opening (BTDC) -21° (so that is 21° ATDC) Intake closing (ABDC) 24° Duration: 183° Exhaust opening (BBDC) 30° Exhaust closing (ATDC) -20° (20° BTDC) Duration: 190° Gross valve lift measured w/1.67 rocker ratio Intake @ cold .003" clearance: ~0.370" Exhaust @ cold .006 clearance: ~0.370" |
Hi im looking to buy a pair of crower stage 1 camshafts, do u know if crower has any offical retailers or do they only sell direct. Becuase i tried looking for their prices and could not find any stores that sells h23 cams.
Re: h23 crower cam specs! no more searching! (jdmaek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmaek »</TD></TR><TR><TD CLASS="quote">Hi im looking to buy a pair of crower stage 1 camshafts, do u know if crower has any offical retailers or do they only sell direct. Becuase i tried looking for their prices and could not find any stores that sells h23 cams.</TD></TR></TABLE>
http://www.google.com |
