b18c1 crx started, died!
Old Jan 5, 2005 | 09:58 AM
dirtydisaster's Avatar
Default b18c1 crx started, died!
Ok, I finnaly got my crx started after doing the GSR swap into it. It ran like crap, now it will bearly even start up. It seems the longer that I let it sit the more likely it is to start up. But if it starts it bearly runs. It Threw the map iat and iacv codes. Can't figure out what the problems are. I've checked and recheck the wiring for the map. It is susposed to be 1.power 2.signal 3.ground. between 1 and 3 there is susposed to be about 5volts. It's right on the money, but if I check between 2 and 3 I also get that voltage. Manual does not say what's susposed to be between the two. I was thinking maybee something is shorting out and the signal is getting power when it shouldn't or something like that. As for the IAT and IACV, I've got no clue. Any help would be great.
obd1 p72 b18c1 jdm
jk conversion harness
Oh yeah, if you guys could also check out this thread, need a little help w/ it. Down on the bottom. https://honda-tech.com/zerothread?id=875862
Old Jan 5, 2005 | 10:40 AM
Default Re: b18c1 crx started, died! (dirtydisaster)
Damnit, as I was posting that I was orange flagged by the cops. Damnit. Need help fast please!
Old Jan 5, 2005 | 11:30 AM
Ok, I just rechecked my distributor wiring, and something is wierd. The ckp is at 5.53 m ohms
the tdc is at 17.11 m ohms and the cyp is at like over 80.00 m ohms. they're all susposed to be between 3.5 to 7. Don't know what is going on. Something seems seriously fu_ _ _ _ up.
Old Jan 5, 2005 | 02:42 PM
acuratech's Avatar
Bro, I have done this myself. Go out to the car, raise the hood, and swap your map, and tps plugs. I have gotten them mixed up, and yours sounds like it is doing the same ****. Repost with what you find...
After i reread your origional post i noticed that you did not throw a tps code. So this may not apply, but might try it for the hell of it...
Old Jan 6, 2005 | 12:37 PM
Default Re: b18c1 crx started, died! (acuratech)
na, the map comes from next to the fusebox, the tps is out of the engine wiring harness. But right on.
Old Jan 6, 2005 | 06:53 PM
eda6's Avatar
peep this
Old Jan 9, 2005 | 05:54 PM
Default Re: b18c1 crx started, died! (eda6)
right on, you got this for obd1 p72?
Old Jan 9, 2005 | 06:06 PM
ok, this could help me, i'm figuring some stuff out w/ it.
caragan11
Oct 13, 2009 02:29 PM
RenX
Jun 18, 2009 07:17 AM
flatblackhatch
Feb 14, 2006 02:07 PM
dirtydisaster
Jun 30, 2005 03:54 PM
speedsightsound
Feb 8, 2004 07:36 PM
