New swap... GSR motor in hatch. help with whistle noise.
Old Jan 5, 2005 | 07:33 AM
pane93civhb's Avatar
Default New swap... GSR motor in hatch. help with whistle noise.
When the motor is just idling there is a whistling sound coming from it.. i was thinking maybe i put the altenator belt on too tight but its really hard to tell were the sound is coming from...
I also have really stiff motor mounts which create alot of vibration.. im not sure but any suggestions in things i should look at would be nice. before the motor was in my car this sound was not there.
Old Jan 5, 2005 | 07:44 AM
AutoXer's Avatar
Default Re: New swap... GSR motor in hatch. help with whistle noise. (pane93civhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">When the motor is just idling there is a whistling sound coming from it.. i was thinking maybe i put the altenator belt on too tight but its really hard to tell were the sound is coming from...
I also have really stiff motor mounts which create alot of vibration.. im not sure but any suggestions in things i should look at would be nice. before the motor was in my car this sound was not there.</TD></TR></TABLE>
Belt tension (tight or loose) can cause squealing noises. Do you have an intake? That can cause a whistle too.
Old Jan 5, 2005 | 07:50 AM
Lee_Delso's Avatar
Default Re: New swap... GSR motor in hatch. help with whistle noise. (EX_AutoXer)
Could be your intake?
Old Jan 5, 2005 | 08:13 AM
there is no intake on the motor yet at all. and its at idle i can be looking right at the engine.. r u talking about the belt tension on the timing belt or the alt.
Old Jan 5, 2005 | 08:26 AM
boostedbseries2000's Avatar
probly on the alt
Old Jan 5, 2005 | 09:11 AM
Default Re: (boostedbseries2000)
ima try and loosen that tonight .. along with swapping in my gsr seats..
Old Jan 5, 2005 | 09:41 AM
TeStUdO's Avatar
Is your throttle body on tight?? If it is on a little loose the gasket will whistle. Also check to make sure your intake mani is tight as well.
Old Jan 5, 2005 | 10:01 AM
Default Re: (TeStUdO)
i will check that as well do u no what this whistle sounds like i meant to record the sound so u can hear it i have like 10 sec video on my phone just so u can hear. it.
o yea and will it cause any other problems besides .. loss of power if they are not tight..
im running codes 1----- and 14 right now that is all.
Old Jan 5, 2005 | 10:10 AM
ek_will's Avatar
Default Re: (pane93civhb)
i think im hearing that same sound after a while of hard running the sound pulsates too.
Old Jan 5, 2005 | 10:14 AM
DALE-EK4's Avatar
Default Re: (dash_0n)
it has something to do with the intake or throttle body.
Old Jan 5, 2005 | 10:18 AM
Default Re: (timnparts)
do u think it may be the gaskets or what. i have the skunk 2 intake manifold and im using the ls throttle body..
Old Jan 6, 2005 | 01:52 AM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">do u think it may be the gaskets or what. i have the skunk 2 intake manifold and im using the ls throttle body.. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">Is your throttle body on tight?? If it is on a little loose the gasket will whistle. Also check to make sure your intake mani is tight as well.</TD></TR></TABLE>
Read my prior post, then get back to us after you check that.
Old Jan 8, 2005 | 07:42 AM
i think the sound stopped. by my car is pretty dam fast for this elevation.. I cant beat SRT-4's but i spanked some rsx's and an S2000 as well. I raced a NSX and he spanked me good. but he couldnt pull away after his intial jump.. he couldnt pull away.. IM still running a cel for my o2 sensor.. and i havent put on my 4-2-1 header. so im happy at this point..
Old Jan 8, 2005 | 08:04 AM
SirRevvs's Avatar
The whistleing comes from the throttle body gasket? I always thought the GSR's did that becasue of the secondaries, interesting.
Old Jan 8, 2005 | 09:00 AM
mr2turbo007's Avatar
i have the same problem with the engine mounts and vibration id like to know if there any mounts out there that would lesson the vibration. I believe i have hasport right now
Old Jan 8, 2005 | 12:11 PM
Default Re: New swap... GSR motor in hatch. help with whistle noise. (mr2turbo007)
hell no keep the engine mounts they keep from all the wheel hop wheel hop breaks ****.. bad.. that is y my stuts are jacked right now.
cbmprelude
18
Dec 16, 2005 06:10 PM
cutzmansi
Sep 13, 2004 01:14 PM
mvaccoRd
Jun 2, 2004 07:16 PM
03 cobra
Jan 18, 2004 11:42 AM
