Weird Oil Pressure Reading.
I just got an oil pressure gauge (brand new)hooked up on my Ls and its reading just about 20 psi at idle. What should it be reading because I know that it should be more than 20 psi. Is my oil pump to weak? If so what do I replace it with?
im pretty sure thats normal..my friend's reads that (on his ls)....but i would like to ask the same question for mine....i have a d16y8 and mine reads about 15psi.(idle) is that accurate its a brand new autometer electric gauge so i dunno i have just assumed its normal for now. i figured my vtec engine would have higher oil pressure than a non-vtec even tho its a soch instead of a dohc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver »</TD></TR><TR><TD CLASS="quote">20psi is normal when the motor is warmed up and idling.
At WOT, the oil pressure should be at around 80psi.
Khoi</TD></TR></TABLE>
Well what does your cart idle at? When mine idles at like 300rpm's I only see 10psi lol
At 800rpm it is around 20psi.
The weight of the oil also plays a role in what pressure you will see. The temperature too, when it's cold, it will be higher.
hatchinprogress
Feb 15, 2006 04:57 PM
