mini-me swap.. what did I do wrong.
Old Jan 4, 2005 | 06:17 PM
mellon's Avatar
Default mini-me swap.. what did I do wrong.
Ok, I got my mini me swap together and cranked it over for the first time ... and it just cranks and cranks. Its getting spark and I haven't checked if its getting fuel, but it smells like it. The weird thing is its blowing air OUT of the intake manifold. The only thing I can think of that would cause this is if I set the timing 180 degrees off. Any ideas?
Old Jan 4, 2005 | 06:23 PM
CimorelliCRX's Avatar
Default Re: mini-me swap.. what did I do wrong. (mellon)
You are dead on, timing is off. Turn the cam gear till your on compression stroke on cylinder 1, which means all the valves are closed.
Then turn the crank till its lined up with the mark on the block. Slide the belt on, give it some tension, try to start it up. And bam, you should be fine.
If its blowing anything out of the intake manifold, then yes, your timing is off.
Old Jan 4, 2005 | 06:34 PM
mellon's Avatar
Default Re: mini-me swap.. what did I do wrong. (CimorelliCRX)
Thanks I think I'm confused about where the cam gear should be. How do I know when its positioned correctly?
Old Jan 4, 2005 | 06:45 PM
The best way with the head on, take the valve cover off, and look at the valves on cylinder 1. They should be all closed, hard to explain, maybe someone else can explain better, but the gear will be all the way up too(mark), so thats a little extra help.
Old Jan 4, 2005 | 06:56 PM
mellon's Avatar
That makes sense
Old Jan 4, 2005 | 07:54 PM
mellon's Avatar
Would bent valves cause air to blow out of the intake mani?
LittlesilverEF
Dec 11, 2009 05:28 PM
TheLastSpartan
Sep 8, 2007 02:09 PM
Speed Infliction
Feb 9, 2007 01:20 PM
Dublin
May 8, 2006 02:17 PM
Bense
19
Jan 27, 2006 12:39 PM
