opinions on my winter project build for b18b turbo
Old Jan 4, 2005 | 09:09 AM
Rob!'s Avatar
Default opinions on my winter project build for b18b turbo
im building a b18b for turbo. here are my plans, i dont know what to set a goal for but i know i wanna make atleast 350whp hopefully more.
b18b longblock unsleeved.
looking at CP or JE pistons
Eagle rods
cometic head gasket
brand new oem bearings
aebs head studs
golden eagle block guard
head will be port and polished and im thinking of getting crower turbo cams but not sure.
turbo kit will be nothing crazy as of now i have a ugraded drag kit. ill be upgrading to a better manifold. bigger tial wastegate and maybe a sc61 turbo if i can afford it.
im new to the built turbo world and im wondering what kinda power i can make if i have a full day of tuning time on hondata keep in mind it has stock sleeves. and what kinda boost range i can run. this car is my daily driver.
ive heard of people making 400 whp on stock b18bs but i am wondering whats a reasonable goal to set. also if you have any suggestions for me on different things to use for my build or anything like that feel free.
rob
Old Jan 4, 2005 | 09:27 AM
primeredbeast's Avatar
Default Re: opinions on my winter project build for b18b turbo (EKsnatchback)
for 350whp you might want to go with something more like a sc34 or sc50 maybe just my .02
Old Jan 4, 2005 | 09:53 AM
Rob!'s Avatar
Default Re: opinions on my winter project build for b18b turbo (primeredbeast)
id like to make more power if the motor is capeable of holding over 400 whp safely on that build i listed.
Old Jan 4, 2005 | 05:01 PM
Rob!'s Avatar
up
Old Jan 4, 2005 | 05:51 PM
drift2004's Avatar
gt2871
Old Jan 4, 2005 | 08:55 PM
blackeg's Avatar
Default Re: opinions on my winter project build for b18b turbo (drift2004)
i would go with oem headgasket, and you probably dont need the blockguard either. the crower turbo cams will really help your powerband stay alive above 6500 rpms, i want to get them bad but cant afford it right now
dont forget to get a decent clutch
Old Jan 4, 2005 | 08:59 PM
s2kdre's Avatar
Default Re: opinions on my winter project build for b18b turbo (blackeg)
damn if all you want is 350whp stock bottom end is good enough wiith good tuning.
Old Jan 4, 2005 | 09:04 PM
Dunc's Avatar
BCICAN
Default Re: opinions on my winter project build for b18b turbo (jdmhonda)
Yea I agree with blackteg 100%. Turbo cams are badass. I personally run Skunk 2 and my power and torque curves are still rising at 7500rpm. Same for a CRX we are tuning.....Crower cams and his hp/torque curves are still rising at 8000-8200rpm.
Old Jan 4, 2005 | 09:19 PM
DefiantGSR's Avatar
Default Re: opinions on my winter project build for b18b turbo (Dunc)
you don't need a SC61 for 400whp.
Go with the SC34. You'll get a much better powerband.
Old Jan 5, 2005 | 05:30 AM
Rob!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">damn if all you want is 350whp stock bottom end is good enough wiith good tuning.</TD></TR></TABLE>
im basically asking what kinda power i can make with the setup i listed, i would wanna make atleast 350 whp it would be very nice to make 450 whp. keep in mind this is my daily driver. im using a clutch master 4 puck clutch. thanks for the responces
Old Jan 5, 2005 | 05:51 AM
blackeg's Avatar
i think you can get your goals and keep the lag down relatively well with an sc34
Old Jan 5, 2005 | 07:02 AM
Rob!'s Avatar
i was also doing some reading on the crower cams. the 402t's looks like im gonna need valve train. i dont plan on reving high do you think the 402's would yield good enough power for my application?
jakoh77
Mar 4, 2012 07:17 PM
cilvercivic
49
Sep 27, 2010 04:59 AM
integraRS-T
Jun 19, 2007 09:46 AM
not2night
Jan 26, 2005 06:59 PM
