TPS Question
Old Jan 3, 2005 | 10:31 PM
d15b7racer's Avatar
Default TPS Question
If your TPS is not set at the right settings will it throw a ECU code or will it just not work correctly?
Old Jan 4, 2005 | 12:02 AM
d15b7racer's Avatar
Default Re: TPS Question (d15b7racer)
anyone?
Old Jan 4, 2005 | 12:43 AM
LASSEN768's Avatar
If the TPS is not set at the right settings, the ecu should throw a code 7.
Old Jan 5, 2005 | 08:17 AM
civic-4-ges's Avatar
Default Re: TPS Question (LASSEN768)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LASSEN768 &raquo;</TD></TR><TR><TD CLASS="quote">If the TPS is not set at the right settings, the ecu should throw a code 7. </TD></TR></TABLE>
Only if they are not within a certain range. The ecu will adjust for slight variations
Old Jan 16, 2005 | 02:36 PM
Xsi's Avatar
Xsi
Yeah it is possible to have tps problems without it showing a code
Old Jan 16, 2005 | 03:49 PM
8krdline's Avatar
Default Re: (Xsi)
if its set at like .69 will it cause a high idle around 2k rpm?
Old Jan 16, 2005 | 04:23 PM
Turbogixxer's Avatar
Default Re: (8krdline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8krdline &raquo;</TD></TR><TR><TD CLASS="quote">if its set at like .69 will it cause a high idle around 2k rpm?</TD></TR></TABLE>
You measure it at closed and full throttle.
Closed = .5
Full Throttle = 4.5
It *May*. TPS only really uses to measure WOT, idle and fast changes of the throttle. Regardless, you should adjust it to spec.
Old Jan 16, 2005 | 09:43 PM
ToxicVTEC's Avatar
Default Re: (turbogixxer)
correct...fuel and ignition maps are based on MAP. TPS is just there for calculating load and stuff like that
lshatch1.8
Jan 8, 2008 12:33 AM
iamhollywood[BRS]
Sep 21, 2006 11:12 PM
imlachg1
16
May 22, 2004 06:04 PM
dpine
Jan 15, 2004 04:20 PM
schtozo
Nov 20, 2003 07:22 PM
