VX O2 fix??? knock sensor???
hey guys... i finished a jdm b18cr into a 92 vx. i used the vx harness and tried to use a p30. the p30 gives me 2 cels: o2 and ks. but no cel with the p7 vx ecu. will a p28 look for the same signals as the vx ecu? the vx ecu only rev up about 6k. can i chip a vx ecu? or is it easier to rewire the o2 sensor and ks - and use a diff ecu? and whcih ecu would work best w/ my set up?
i have two o2 sensors: one is the vx o2 which has 5 wires, the other is a 4 wire.
what would be the best fix for my prob?
the p07 sputters at low rpms... is this because of the maps? or should i upgrade the fuel pump?
i can pay or donate to ht $20 for info that helps most.
Modified by eggie75 at 9:06 PM 1/3/2005
Modified by eggie75 at 9:08 PM 1/3/2005
Here is my how-to. Hope it helps. Just ignore the part about the secondaries.
https://honda-tech.com/zerothread?id=644434
BamBam0260
16
Mar 16, 2013 09:18 PM
garyhgaryh
Oct 17, 2007 02:55 PM
Sam1am26
Oct 18, 2005 01:45 PM
