No Butterflies versus P72 ECU
Old Jan 3, 2005 | 12:07 AM
THEUSED's Avatar
Default No Butterflies versus P72 ECU
My IM on my GSR has its Butterflies taken out will this affect a P72 Ecu, will I throw codes? Should I even bother Wiring them up if not will I throw codes? Should I use my P72?
Old Jan 3, 2005 | 11:09 AM
boricuatuning's Avatar
Default Re: No Butterflies versus P72 ECU (THEUSED)
no. It will not give you a code.
Old Jan 3, 2005 | 02:46 PM
dfoxengr's Avatar
Default Re: No Butterflies versus P72 ECU (boricuatuning)
get a p28 and itll fix it.
Old Jan 3, 2005 | 03:55 PM
TeStUdO's Avatar
Default Re: No Butterflies versus P72 ECU (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">get a p28 and itll fix it.</TD></TR></TABLE>
True, but running p72 with no butterflies wont hurt anything.
Old Jan 3, 2005 | 04:04 PM
dfoxengr's Avatar
Default Re: No Butterflies versus P72 ECU (TeStUdO)
youll get a code
Old Jan 3, 2005 | 07:45 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">youll get a code</TD></TR></TABLE>
What code will you throw??? The butterly runs off vacuum. I ran mine for 3 years with the butterflies took out. There isnt one code that I can find for the IAB.
Old Jan 4, 2005 | 05:19 PM
StorminMatt's Avatar
The P72 DOES control the butterflies by means of a vacuum solenoid. But it won't throw a code if there is nothing connected.
Old Jan 5, 2005 | 05:14 AM
JimBlake's Avatar
Default Re: No Butterflies versus P72 ECU (StorminMatt)
OBD-1 P72 doesn't have a code for IAB at all.
I think OBD-2 has a code if the IAB solenoid valve is gone. If that valve is in the circuit, but the vacuum hoses aren't connected; the ECU has no way to know the actual valves aren't working.
Old Jan 7, 2005 | 09:15 AM
Jun8386's Avatar
Well, P72 has to have a knock sensor. Your best bet is to get a P28 and have it chipped. Only problem you might get is a vacuum leak from removing the butterflies. I run a spoon chipped P28 and I pull harder from a stop than a gsr w/butterflies and a P72.
Old Jan 7, 2005 | 09:43 AM
TeStUdO's Avatar
Default Re: No Butterflies versus P72 ECU (Jun8386)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jun8386 &raquo;</TD></TR><TR><TD CLASS="quote">Well, P72 has to have a knock sensor. Your best bet is to get a P28 and have it chipped. Only problem you might get is a vacuum leak from removing the butterflies. I run a spoon chipped P28 and I pull harder from a stop than a gsr w/butterflies and a P72. </TD></TR></TABLE>
What does this have to do with manifold butterflies? If the block has a knock sensor he has nothing to worry about.
Old Jan 7, 2005 | 01:10 PM
Jun8386's Avatar
I might not be right but the P72 has to have a knock sensor. if the knock sensor isn't ran then the car wont start. with a p28 u only have to have v-tec, ground, and oil pressure for it to run. Right?
Old Jan 7, 2005 | 02:31 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jun8386 &raquo;</TD></TR><TR><TD CLASS="quote">I might not be right but the P72 has to have a knock sensor. if the knock sensor isn't ran then the car wont start. with a p28 u only have to have v-tec, ground, and oil pressure for it to run. Right?
If there isnt a knock sensor you will throw code 23 that is all
Old Jan 7, 2005 | 06:55 PM
Jun8386's Avatar
I was wrong about it not starting but I dont think v-tec will kick in if there isn't a knock sensor with a p72. Right?
Old Jan 8, 2005 | 03:08 AM
THEUSED's Avatar
I think vtec doesnt kick in since not having the knock makes the ECU go into Limp mode
nicko360
15
Nov 2, 2007 04:24 AM
I CRX I
Sep 30, 2007 07:09 AM
Dr Pooface
Nov 29, 2005 09:23 PM
GWInquisitor14
Jan 25, 2005 07:37 PM
GDM Z28
May 2, 2004 02:14 PM
