got a jdm dc 4-1 header (some questions)
Old Jan 2, 2005 | 10:58 PM
Scubster's Avatar
Default got a jdm dc 4-1 header (some questions)
I just bought this header and want to install it on my car. Will the s2000 flange work with a stock cat? where would i order the 2.5 in donut gasket? also what kinda of gains could i expect? i have an ls/vtec with pr3 pistons and stock gsr head with skunk2 Im, chipped ecu, intake and exhaust. I was running a U.S dc 4-2-1 before (yea i know, crap) should i expect a noticable difference? thanks guys
Old Jan 2, 2005 | 11:26 PM
d555's Avatar
Default Re: got a jdm dc 4-1 header (AllM0tadc2)
you could gain up to 20 hp.
Old Jan 3, 2005 | 05:15 AM
dFreezy's Avatar
Default Re: got a jdm dc 4-1 header (david555)
correct, you will need a 2.5" donut flange (one from an s2000 would work), but you won't be able to use your stock cat because its too small. you should consider getting a 2.5" carsound cat. the donut flange should be available from your local honda dealership, places like inlinefour.com also sell them.
Old Jan 3, 2005 | 08:25 AM
Rollo Lawson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david555 &raquo;</TD></TR><TR><TD CLASS="quote">you could gain up to 20 hp.</TD></TR></TABLE>
you are a cerified Jabroni. 20 hp? LOL. you'll make some power up top, but, not much. maybe 3-4whp. and i don't think that its worth it because you'll smash it in the first week and lose a bit of exhaust flow which will probably end up making the same hp as an undented 4-2-1. i would not be suprised if you put a 2.5" collector on the 4-2-1 and made roughly the same hp as the dc jdm 4-1. yes, its your best bang for your buck, but, only if you don't mangle it, and don't drive it in the winter. dc header rust terribly. g/l
Old Jan 3, 2005 | 09:37 AM
Scubster's Avatar
Default Re: got a jdm dc 4-1 header (B16C1)
yea 20 hp did sound like a lil too much. The only reason i actually got the header is because someone traded me staight up for my 4-2-1. so i thought it was a good deal. anyone else have an opinion?
Old Jan 3, 2005 | 09:49 AM
xprohx's Avatar
I think too much
What I did was bought a 2.5" s2000 donut gasket from a honda dealer for like 23-ish dollars. The stock cat wont fit, and I bought a 2.5" in and out carsound cat from ips racing. Take it to a muffler shop and they can weld on flanges to the cat so it will bolt up to your current exhaust system.
Old Jan 3, 2005 | 10:17 AM
Scubster's Avatar
Default Re: got a jdm dc 4-1 header (xprohx)
that sounds like a good idea. So the 2.5 inch carsound cat will still work with my 2 and a 1/4 piping right?
Old Jan 3, 2005 | 11:45 AM
xprohx's Avatar
I think too much
The muffler shop should be able to make it fit.
Old Jan 3, 2005 | 01:36 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllM0tadc2 &raquo;</TD></TR><TR><TD CLASS="quote">that sounds like a good idea. So the 2.5 inch carsound cat will still work with my 2 and a 1/4 piping right?</TD></TR></TABLE>
You can order a 2.5" cat from SMSP that will be a direct bolt-on. He can also supply you with the donut gasket you need.
Old Jan 3, 2005 | 03:10 PM
Scubster's Avatar
Default Re: got a jdm dc 4-1 header (Padawan)
will my 2 and 1/4 piping be hurting me?
Old Jan 3, 2005 | 04:39 PM
Padawan's Avatar
Darth ModerVader
It won't be ideal, but a simple and easy upgrade you could make to your 2.25" exhaust is to install a a 2.5" -&gt; 2.25" tapered adapter at the flange that connects to the cat, thus providing a smooth transition between the two pieces.
Old Jan 3, 2005 | 06:03 PM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">You can order a 2.5" cat from SMSP that will be a direct bolt-on. He can also supply you with the donut gasket you need. </TD></TR></TABLE>
thats what i did
Old Jan 4, 2005 | 06:40 PM
jmk2888's Avatar
You can buy a Donut for a CRV, it's cheaper than a S2000.
https://honda-tech.com/zerothread?id=1067321
Old Jan 5, 2005 | 09:25 AM
Scubster's Avatar
Default Re: got a jdm dc 4-1 header (jmk2888)
great info thanks
98cwitr
Sep 4, 2003 10:17 AM
STEALTHMODECOUPE
11
Apr 21, 2003 03:36 PM
2qwik2nv
Apr 9, 2002 01:21 PM
lePetitePrince
Oct 11, 2001 10:56 AM
GSR
Aug 19, 2001 11:01 PM
