Need help...People with Del Sol's....
Old Jan 2, 2005 | 02:37 PM
_Spugen_'s Avatar
Default Need help...People with Del Sol's....
I just picked up a sol and the rear piece where the liscence plate goes is dented....The owner included another piece, there is four bolts that hold it on then another two behind the liscense plate. They have some sort of circle bolt on it and Im completly confused on how to remove it...Anyone?
Old Jan 2, 2005 | 02:51 PM
civictildeath's Avatar
Default Re: Need help...People with Del Sol's.... (SpugenEG)
any way you can get a pic of it??
Old Jan 2, 2005 | 02:53 PM
gt30typer's Avatar
It sucks but vice grips, it is the only way since it is not like a normal nut, no big deal though you never see it later on.
Old Jan 2, 2005 | 04:41 PM
_Spugen_'s Avatar
Thanks.
Old Jan 4, 2005 | 12:00 PM
Del Sol SiR's Avatar
Default Re: (SpugenEG)
Vise grips Replace the circle nuts with regular nuts!
Old Jan 4, 2005 | 01:07 PM
Fonzo's Avatar
Default Re: Need help...People with Del Sol's.... (gt30typer)
Thats how i did mines
Old Jan 4, 2005 | 04:25 PM
SolBreak's Avatar
i had the same problem....just take off the liscense plate and drill it out. it will look just fineif you put bolts in each hole, plus the liscense plate covers it. start small with the rill bits, and gradually get bigger untill the bit is bigger than the bolt stem......you'll feel it when it pops.
Old Jan 4, 2005 | 05:04 PM
nfinitecc's Avatar
Default Re: (SolBreak)
yea i drilled mine out to. Worked great
Old Jan 4, 2005 | 05:11 PM
TrackSol's Avatar
Drilling??? Yikes!!!
I used used vice grips with one hand while pushing in from the outside with the other hand to relieve stress. Then I replaced them with regular nuts.
Old Jan 5, 2005 | 08:47 AM
_Spugen_'s Avatar
Got it off yesterday..thanx
SubSero
Apr 13, 2017 08:01 AM
typac69
12
Aug 7, 2009 09:00 AM
Wakes4Fun
Aug 2, 2009 06:18 PM
Jamarquis
Paint and Body
Jul 10, 2008 08:38 AM
DelSolSi93
Feb 22, 2005 09:53 PM
