Timing adjustment on a '90 Integra
The timing on my '90 integra was accidentally thrown off so I wanted to put it back to spec, but am having trouble with a few things. First off I wanted to make sure the first cylinder (the one the timing gun should be attached too) is the one furthest from the distributor. Second where is the service connector that I need to jump located?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bladesoxy »</TD></TR><TR><TD CLASS="quote"> First off I wanted to make sure the first cylinder (the one the timing gun should be attached too) is the one furthest from the distributor.
thanks</TD></TR></TABLE>
yep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bladesoxy »</TD></TR><TR><TD CLASS="quote">Second where is the service connector that I need to jump located?</TD></TR></TABLE>
passenger side kickpanel under dash. i forget what color the connector is but it has two wires going into it.
yep
