Timing is off need some HELP!!
Old Mar 31, 2005 | 11:27 PM
sol_1320's Avatar
Default Timing is off need some HELP!!
I check my timing today and in order for me to get TDC 16 deg. I half to advance my distributor almost all the way anyone know why this is, I always thought it was suppose to be somewhere in the middle. I did a search and didn't really find an answer. Unless my belt is off by a couple teeth
My engine
Bone stock B18a
Old Mar 31, 2005 | 11:31 PM
PrettyLude's Avatar
did u jump the service connector?
Old Apr 1, 2005 | 08:00 AM
sol_1320's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">did u jump the service connector?</TD></TR></TABLE>
I never did I'll try that, thanks
Old Apr 2, 2005 | 03:55 PM
sol_1320's Avatar
Well I tried it and it stayed the same, I adjust the idle and that fixed it.
What is the jumper really suppose to do for the timing?
Modified by sol_1320 at 8:53 PM 4/2/2005
Old Apr 2, 2005 | 08:15 PM
Lord Helmet's Avatar
Default Re: (sol_1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol_1320 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by sol_1320 at 8:53 PM 4/2/2005</TD></TR></TABLE>
It's to put the engine in to diagnostics mode. It to let you adjust the engine without the ecu trying to over rule the adjustments you made.
BTW is your camshaft marks and crankshaft pulley marks at the right positions?
Old Apr 2, 2005 | 10:22 PM
sol_1320's Avatar
Default Re: (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">
It's to put the engine in to diagnostics mode. It to let you adjust the engine without the ecu trying to over rule the adjustments you made. </TD></TR></TABLE>
O.K is it suppose to show a check engine light, when u do this because the first time my check engine light came on then i tried it again and it was off.
So,then the next time when I want to advace the timing then i still want jumper the cable right? I assume yes just want to make sure
BTW is your camshaft marks and crankshaft pulley marks at the right positions?</TD></TR></TABLE>
Yea, all in the right position
Old Apr 2, 2005 | 11:06 PM
PrettyLude's Avatar
yes the checklight is supposed to come on when the wire is jumped
Old Apr 3, 2005 | 06:13 AM
sol_1320's Avatar
Thanks for the help guys
Old Apr 14, 2005 | 09:38 AM
RoyMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">yes the checklight is supposed to come on when the wire is jumped</TD></TR></TABLE>
hmm my check engine light is not coming on when i do that....b16a1, 89 crx dx
Old Apr 14, 2005 | 11:05 AM
PrettyLude's Avatar
Default Re: (RoyMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoyMan &raquo;</TD></TR><TR><TD CLASS="quote">hmm my check engine light is not coming on when i do that....b16a1, 89 crx dx</TD></TR></TABLE>
if im not mistaken, that is code zero, ur ecu fubored
Old Apr 14, 2005 | 11:29 AM
purduinasi's Avatar
Well, the code doesnt come on when the harness is jumped, but it still throws regular codes at other times. Could it just be that wire? The ECU came with the swap from Hmotorsonline, so i wouldnt think that it would be bad...
Old Apr 14, 2005 | 11:32 AM
RoyMan's Avatar
Default Re: (purduinasi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purduinasi &raquo;</TD></TR><TR><TD CLASS="quote">Well, the code doesnt come on when the harness is jumped, but it still throws regular codes at other times. Could it just be that wire? The ECU came with the swap from Hmotorsonline, so i wouldnt think that it would be bad... </TD></TR></TABLE>
ya im beginning to think it may just be that wire bobby, everythine else with the ecu is working fine. well i still need to wire vtec right (speed sensor isnt wired right)
JDM_rolex
Jul 19, 2006 03:58 AM
platinum00
Dec 17, 2004 08:53 AM
skeematic
Nov 24, 2004 10:53 PM
Sinner
Jul 1, 2004 11:32 AM
KooK
11
Jun 4, 2003 09:26 AM
