oil sandwich adapter
hey i had a question about the golden eagle oil adapters. They say you can use it to tap off for ls/vtec or as a turbo feed line, but can you do both? it looks like there are 2 holes in it, so can you use one for vtec and one for the turbo?
TIA
TIA
Yes you can. I ran a 3AN line for the feed and just plugged the 3/4 port(on my LS-t). I felt that using the GE adapter was the cleanest and easiest method for the turbo feed.
Phil
Phil
I was just looking at Greddy's site. I'm thinking I may grab one of these. Can I use this adapter and run oil pressure gauge sensor, oil temp sensor and the turbo feed off this adapter? Can the B&M take-off plate fit on top of this adapter so I can still use my remote oil filter housing and cooler?
awdriscol4
Jul 10, 2005 10:06 AM
